Engine Knock
Old Apr 22, 2005 | 09:44 AM
spdnman's Avatar
spdnman
Default Engine Knock
What exactly does knock sound like? The car seems to drive fine, but there is a banging noise. It sounds like it could be a loose exhaust pipe or header,etc., but I'm not sure. I notice it mostly in park. With hood up, it sounds very low in the engine compartment. Any suggestions? BTW, Just had a Tunnel Plate installed. Thanks.
Old Apr 22, 2005 | 09:58 AM
yellow01's Avatar
yellow01
If you knock bad enough to hear it, it sounds like, as best I can describe, like wrapping a metal wrench in a towel and hitting another heavy piece of metal. Kind of like a very short/intense thunk.
Ping on the other hand sounds a little different, much higher pitch. I had horrible pinging in my '01 on a dyno once and it sounded like they were making popcorn under the hood... ick.
If you're hearing a less muffled banging, I would suggest is is probably something loose and not engine knock, especially given your recent install. The exhaust has to be dropped for that install, and maybe they missed a hanger or something? or didn't tighten something up?
Also just saw you heard it mainly in 'Park', doubt highly you'd get any knock at idle.
Old Apr 22, 2005 | 10:01 AM
samhane's Avatar
samhane
http://www.pistonslap.com/photos.htm
They have an audio file of what piston slap is. See if this is your noisie.
To Engine Knock
