Dyno #'s are In.
Old Apr 22, 2005 | 09:48 AM
highpressuremax's Avatar
highpressuremax
Default Dyno #'s are In.
98 mn6 106,000
Max Power= 368.77 Max Torque=364.48
Just had the following installed. Comp 224/224 .581 114, springs/pushrods, slp oil pump, Double roller timing chain, ASP under drive pulley, spec 2 clutch, Dynotuned.
Already had Borla stingers, Dynamaxx Headers, K & N intake and electric water pump.
Before the install I dynoed at 333hp on a mustang dyno, Current #'s are from a Dynojet.
#'s seem really low, what do you guys think. thanks
Old Apr 22, 2005 | 09:50 AM
new vetter's Avatar
new vetter
Originally Posted by highpressuremax
98 mn6 106,000
Seems about where it should be. Good heads will get you close to 400 rwhp.
Old Apr 22, 2005 | 09:52 AM
yellow01's Avatar
yellow01
Numbers look ok to me. I'm with the above, heads may allow all the other mods to take a more full effect.
Old Apr 22, 2005 | 09:54 AM
SideStep's Avatar
SideStep
365-370 rwhp (SAE ???) seems right in-line for your mods.. What was your final AFR at WOT???
FYI, an LS6 intake will be worth an honest 10-12rwhp....
Old Apr 22, 2005 | 11:18 AM
ChipN's Avatar
ChipN
Hi John,
Could you post your Dyno chart? I'm curious to compare it to mine since I recently had similar work done (different cam and headers) and came out with similar numbers. My car is an '04 and should have the LS6 intake manifold, but it is also an A4 which robs some of the power. Probably somewhat of a wash all-in-all.
Just curious more than anything.
Chip
Old Apr 22, 2005 | 11:45 AM
highpressuremax
sorry, I dont know how to resize the pic.
Old Apr 22, 2005 | 04:14 PM
loudsam's Avatar
loudsam
Your dyno graph is really "cute"! Nice #'s though in my opinion. Congrats on the new power, should be a strong running car!!!
Old Apr 22, 2005 | 04:31 PM
pdd000's Avatar
pdd000
[QUOTE=loudsam]Your dyno graph is really "cute"! QUOTE]
Old Apr 22, 2005 | 07:12 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Same numbers I have on my Y2K and it has 16000 miles
Old Apr 22, 2005 | 08:02 PM
highpressuremax
thanks guys, I really thought the numbers would be higher. I dynoed on a mustang before the install 336 h.p dont remember what the torque was.
anybody know what 333 hp would be on a Dynojet.
To Dyno #'s are In.
