Check Engine Light
Old Apr 23, 2005 | 08:00 AM
Lancer033's Avatar
Lancer033
Default Check Engine Light
got a steady check engine light yesterday afternoon, but I think I've fixed the problem
When I changed my plugs last week, I dropped one of the old plugs down between the exhaust manifold and the metal cover that goes over it. To get it out, I had take out the screws that held it on and pull it back a little. When I put everything back together, I didn't tighten down one of the screws
the owner's manual and a few posts I found on the forum said that a steady check engine light was a problem with the emmissions system, so I'm thinking that is what caused it, and after fixing the problem, the check engine light should go away after driving the car for a while. (How long?)
While I was at it, I also checked the codes and this is what I got. All of them were history codes, so I don't think there are any problems.
10 - PCM - P1416H Secondary Air Injection (AIR) System
28 - TCS - C1214H Circuit Open
60 - IPC - B0516H Speedometer Signal Circuit Malfunction
60 - IPC - B0521H Tachometer Signal Circuit Malfunction
60 - IPC - U1255H Class 2 Communication Malfunction
A0 - LDCM - B2282H Battery #1 Circuit
A0 - LDCM - B2284H Battery #2 Circuit
A1 - RDCM - B2285H Battery #2 Circuit
A1 - RDCM - B2263H Mirror Position Sensor Signal Circuit
A1 - RDCM - B2265H Mirror Position Sensor Signal Circuit
edit: yeah my engine bay is dirty, sue me
Old Apr 23, 2005 | 10:29 AM
Lancer033's Avatar
Lancer033
never mind, the check engine light went out as soon as I backed out of the garage.
Old Apr 23, 2005 | 10:59 AM
Patches's Avatar
Patches
Congrats on the fix. That's what really counts!
Old Apr 23, 2005 | 02:17 PM
Lancer033's Avatar
Lancer033
Thanks Patches. I'm learning as I go; one of these days, I'll get through a job without any problems.
To Check Engine Light
