door sill trim
Old Apr 23, 2005 | 10:24 AM
WLDHRSE's Avatar
WLDHRSE
Default door sill trim
I am painting my coupe and was wondering what you guys have done about this black trim piece. It appears to be molded in, is that correct? I have not taken a real close look at it to see if it can be removed. I hate to just mask things off that can be removed. What do you think?
Thanks,
Cliff
Old Apr 23, 2005 | 08:23 PM
NoNeck's Avatar
NoNeck
I thought it just stuck on with adhesive.
Old Apr 23, 2005 | 10:30 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
It's a vinyl piece. They come off easy. Use a hair dryer to slightly heat it if you need to. I found that this just seems to leave more adhesive behind for you to clean. Use somthing like 3M adhesive remover to get the glue off.
Old Apr 24, 2005 | 11:35 AM
WLDHRSE's Avatar
WLDHRSE
Does this piece normally come off in good shape so that it can be used again? Or should I plan on replacing it?
What are some other options for replacing it?
Thanks,
Cliff
Old Apr 24, 2005 | 01:40 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
my 98 did not come with them (I believe they started putting them on 99 and later cars), I installed them myself.
checkout your local chevy dealer, they are not very expensive.
Old Apr 24, 2005 | 04:47 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I've seen a few on eBay in different colors and sizes.
To door sill trim
