Leaking LT collectors
Old Apr 23, 2005 | 01:42 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Leaking LT collectors
I have a set of Original (non Borla) LGM LTs I purchased about 2 years ago. They are leaking at the tube/ collector junction. Both sides are leaking - right and left at the same area.
Anyone else have this problem??
They're Jet-Hot coated....is it difficult to clean up the surface and weld them?? TIA.
Old Apr 23, 2005 | 02:50 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Leapin' lizards, leaking LT collectors???? .
I'd try contacting LGM to see if they can repair of replace them.
Old Apr 24, 2005 | 01:09 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
They're leaking at the junction of the individual cyl tubes as they enter the collector - not at the X-Pipe/collector junction. Looks like they're tacked and not a circumferential weld.
Is this a common problem??
I ordered a set of Kooks 1 7/8" and a 3" X-Pipe.
I'm going back to Cats and closed loop (hopefully?).
I guess I'll sell this Catless setup.
Old Apr 24, 2005 | 03:35 PM
'06 Quicksilver Z06
Can't go wrong with the KOOKS.
Old Apr 24, 2005 | 03:38 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
My kooks leak
Old Apr 24, 2005 | 03:51 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Originally Posted by phils C5 vette
My kooks leak
At the tubes/collector or attacment of the X- Pipe to the collector?
Have you talked to Kooks?
Old Apr 24, 2005 | 04:19 PM
'06 Quicksilver Z06
My kooks leak
Out of curiousity, where?
I had a leak where the driver side header flange bolts to the x pipe flange a while back.
The system uses a 2 bolt flange arrangement here. One of the two self locking nuts on the drivers side flange didn't want to self lock. A lock washer solved that.
To Leaking LT collectors
