180 degree thermostat. . . . . Where?
Old Apr 27, 2005 | 10:53 AM
TopCat's Avatar
TopCat
Originally Posted by George V
My 160 give me 169 on the highway on a 50-degree day, oil is about 190. Is that too cold? Do I just have cold running 160?
I'd say your oil temp is fine (anything over 180 will force out moisture and fuel), coolant may be a little cool. If you see my first post above, I was running mid 170's with outdoor temps @ 34F. Pumba also gives good data based on what I've seen. Since your oil is at 190, it could be that your temp. sending unit is off a little and you may be closer to 175. Otherwise, yes your stat could be off a little. Will it matter? Could be a bit of an issue on engine clearances. Will it shorten the life of your engine? Doubt that anyone could prove that it would; 'bout like asking if an x-ray at your dentist's office would shorten your life. Risk of running the lower temp = minimal. Can you run too cold? Certainly....if it were me I wouldn't go any cooler than where you're at, but you have to consider oil and tranny fluid temperatures also....and your oil looks fine. Should you check your coolant temp to see if it's the sending unit? I would. Should you change your t-stat? Personally, if I found it was truly 169F, I'd take the stat out, test it on the stove, find out what temp it begins opening, and if it wasn't 160F, I'd contact Hypertech and see if they'd swap it out for me.
REMEMBER: Take the time to test your stat in hot water on the stove with a thermometer. Only takes a minute and you'll have peace of mind knowing that your t-stat works as promised (it's fun to watch and learn, too!)
I forgot to put in one more plug for lower temperatures - slows corrosion!!! Corrosion inside the engine due to blowby contaminants, water, etc. accelerates the higher the temperature....includes aluminum corrosion within the cooling ports in the engine and corrosion in the radiator.
DexCool isn't impervious to negative effects caused by thermal breakdown either. It contains anti-corrosion and lubrication additives that break down faster the higher the temperature....not to mention the thermal breakdown of all other fluids affected by temps.....air compressor oil, power steering, brake fluid, engine oil, tranny fluid, windshield washer fluid , etc. and the effect of extra heat on the other major components under the hood.
What's the downside? Decarbonizing the cylinder heads
Oh .............. wait ..... we have to do that anyway
Old Apr 27, 2005 | 11:11 AM
TopCat's Avatar
TopCat
Originally Posted by Dan_the_C5_Man
Good post Top Cat..
And thank you for clarifying this point; "Either experiment with a stock stat to get to 180 like Dan or go the simple route and put in a Hypertech 160 and get 175-180 all summer long. Note: if in cold climates, winter driving will necessitate switching back to the stock stat to maintain proper operating temps."
The stock C5 cooling system w/ a stock (or close to stock) motor has enough capacity to bring the engine coolant down to below 160. If I had to guess you could probably get it down to the 140's w/ no t-stat, depending on the out side temps. The point here is that a 170 degree stat is probably ideal (supplying us w/ 180 temps year-round), but as far as I know the only "reputable" company that makes aftermarket t-stats sell either 160 or 180. There are forum vendors that sell "170*" t-stats, but they look like modded stock stats. I figured I'd do the same thing on my own, only cost being a bit of my time.
Thanks Dan, and good additional points. Glad you brought up the inferior 170 (also 172F) stats....don't know if they're "made" the same way still (cut springs if I recall correctly).
I agree, a 170 would be perfect (business opportunity??)
Speaking of learning, you had to remove the guts of the thermostat to get to the socket in the stat housing where you inserted the shim, thereby increasing the force against the large spring, right? Allows the wax pellet to open the stat at a lower temp? Did you test in hot water to get to the right shim thickness? I might re-modify my stock stat and create a combo cut spring/shimmed stat for grins.
Old Apr 27, 2005 | 11:50 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Basically, disassembling the stock stat isn't difficult, just a pain in the a$$. You have to push against the force of the spring while rotating at the same time to get the top bracket to unhook from the cast body..
The theory behind shimming the shaft is that you are "preloading" the wax pellet, i.e. taking up additional space in the chamber.
I had a good starting point (as far as shim size goes) and then I trial'd and error'd with it in a pan on the stove.
I only had to take it off the car to redo it once; most folks probably would not have bothered (it was running at 175) but I wanted it "perfect".
I hit it right on the second time around. Precisely 180*.
A suggestion; DO NOT go for the "cut spring” method! I ruined my original stat by doing that, even though I followed the procedure to a "t" as to how much spring to remove. My guess is different model years had different number of windings and / or thickness of wire. I ended up having to buy a used stat off the forum to do the shim mod.
Old Apr 27, 2005 | 11:51 AM
Dan_the_C5_Man
Originally Posted by Korreck
I woukd say that's about 10 degrees on the cool side.
Bob
Old Apr 27, 2005 | 12:24 PM
Av8ter's Avatar
Av8ter
Av8ter, you were a little confusing AND misleading.
Funny thing, I thought the exact same thing after reading your post.
Of course, I may just confuse the issue more .
Sigh, rest assured, you succeeded. As for the rest of your post, I dont even know where to start. Everything I said in my previous post is EXACTLY how the cooling system operates and why when using lower temp thermostats that you dont get the engine temp that the thermostat is rated for. The stock system was designed to work TOGETHER as a MATCHED system. You people that go and change thermostats to something with such a low temp rating (160) but dont change anything else to compensate (larger radiator), youve essentially taken the thermostat out of the loop. Its only purpose now is to quickly warm the engine up to 160, afterwards, its constantly wide open and is prevented from doing its job. At this point, the coolant just flows straight through.
Uh, yes and no. This could be misunderstood as meaning that the engine won't be able to cool the engine because you have too much coolant flowing.
The engine wont be able to cool the engine?? What does that mean??
Let's make it clear, if you increase flow of either component (air or coolant) you will increase cooling. It's basic thermodynamics that correlates heat transfer to mass flow. More heat is removed per unit time, e.g. BTU per minute, through the radiator at a higher flowrate through the radiator.
Wrong. That statement applies to a correctly designed and matched cooling system, not one that's been modified with a lower temp thermostat. If more heat were removed through the radiator due to a higher flow rate of coolant, then you would see temps get down to 160. And a higher flow rate of air is irrelevant because the stock radiator just doesn't have the size/capacity to keep up with that low of a thermostat. The fact is that with a 160 thermostat the coolant is flowing too FAST through the radiator and is unable to dissipate the heat before it leaves the radiator to go back into the engine. That's why you see 15-20 degrees higher temps.
If you're running 194F with a stock t-stat, the 'leaving radiator temperature' may be, for example, 184F (delta T = 10F). However, the air temperature coming out of the radiator into the engine compartment approaches 194F, heating the underhood components and the firewall/floorboards of your C5.
Yeah, and? When you open the hood and look down, have you noticed that big hole at the bottom where you can see the street? When youre going down the highway and air is rushing under the car and up into the engine compartment, the heated air leaving the radiator isnt even an issue in the engine compartment.
We don't want 160F coolant, we want 175-180F coolant to minimize wear and increase performance, albeit sacrificing some in emissions (from startup to 174F temps since the cats don't work well until they heat up).
Granted, using a 160 stat is a stopgap measure and not technically correct (vs. a 180 stat with a proper sized radiator), but it works, and works well.
Exactly, and with a 180 thermostat, a proper sized radiator, and correct fan settings, you would have very consistent temps ALL YEAR long.
For clarification also to those reading this, the t-stat is on the downflow side of the engine and there is a lag between the time the coolant heats up and the time the t-stat 'sees' the hotter water and opens up further to increase flow to the radiator. It is not instantaneous.
This lag time you mention is insignificant. What are we talking here, 30 seconds for the water to go from the inlet of the block to the outlet?
....... you are correct in explaining why the engine operates at a temperature that's higher than the rating of the thermostat..... because the radiator doesn't have enough fin surface area to transfer the heat to the volume of air passing through it, or because there isn't enough air passing through the radiator for the number of fins.
After all that, now im correct?..LOL
So what? This is written up like it's a bad thing. Those of us that use the 160 don't use it to try to get 160 coolant temperatures, we use it to get close to 180 (BTW, the only way I know of to get right at 180 is like Dan_the_C5_Man did...modify an original t-stat....I did similar by cutting the coils, but didn't like the way the spring was seated in the housing afterwards).
If you want to modify it to 180, install a .101 shim in the thermostat housing in that little hole where the thermostat nipple engages the housing.
You must not have enough experience with 160 stats because that's not true.
Sigh,,,,,,,,,,,,
As a matter of fact, my temperature fluctuated WAY more with the stock stat than with the 160.
No. The FACT is that if you didn't modify the fan settings, your engine temp would fluctuate MUCH more AFTER installing a 160 thermostat. Because while going down the highway, you may get around 175-180 in temps, but while sitting in traffic, you will see up to 230. That's a possible 45-50 degree difference which has to be expanding and contracting the engine and components all over the place and cant be good for it. So the ONLY way your statement could be true is that after you installed the 160 thermostat, you modified the fans to operate much lower which would somewhat minimize temp fluctuation. A stock thermostat at 194 would fluctuate up to 230 before the fans would kick up to high speed and would be a difference of 35 degrees.
Considering how consistent my temps are, it wouldn't surprise me if the engineers designed the LS1 to run at 175-180 with a 160 stat,,,,
No. The engines temps were designed with many factors involved including power, longevity, emissions, fuel economy, etc. etc. Im sure the GM engineers did quite a bit of homework to come to these conclusions.
My initial post was to explain how the cooling system works and especially how it works as a matched system. Now granted the stock fan setting will allow the engine to get into temp ranges that will reduce power, especially when getting over 200. Ive modified my engine quite a bit and have the fan settings changed to come on lower as well, but I still run the stock thermostat and it runs just fine. Like ive mentioned before, my engine runs at 190-194 ALL year long, no KR, and makes plenty of power. Screw the hassle of changing parts out depending on the season. I learned a long time ago that if youre going to modify something, do it right and you wont have to deal with it again.
Old Apr 27, 2005 | 12:27 PM
Av8ter's Avatar
Av8ter
Good post Top Cat..
If you modified the stock thermostat to change it to 180 AND had a larger radiator to compensate, then you could get 180 [/b]ALL YEAR LONG[/b] consistent engine operating temps and wouldn't have to change it again at all. Why create more hassle?
After the engine is warmed up with a 160 thermostat, it is already WIDE OPEN and its essentially the same as not having a thermostat at all and there is no way that with a stock radiator that it will get anywhere close to 140 or even 160 unless its very cold outside.
Old Apr 27, 2005 | 01:10 PM
Av8ter's Avatar
Av8ter
edit
Old Apr 27, 2005 | 01:29 PM
TopCat's Avatar
TopCat
Never made a typo before Av8ter? Oh, wait a minute.....what's wont mean?
My only purpose was to support the use of a 160 stat and clarify your misstatement, which you repeated....
More heat is removed, that's why I'm down at 176 on the interstate and you're at 196. Nobody ever said a 160 stat would give you 160 coolant. Sigh..............
Old Apr 27, 2005 | 01:58 PM
Dan_the_C5_Man
It's clear you are not speaking from first-hand experience..
I am.
I have a stock radiator. My engine runs at 180 w/ my modified stock t-stat, not lower, not higher, on the freeway, 365 days a year.. I live in Georgia where the temps vary from 25* to 95*.
Anyone w/ common sense knows the temps will rise when you are stopped. That's what fans are for..
My temps dropped below 160 when I had a 160 t-stat installed. The stock cooling system is not as under-engineered as you think it is. If that's not your experience, you have a "problem" (or non-stock configuration) with your car.
Old Apr 27, 2005 | 02:07 PM
Av8ter's Avatar
Av8ter
And what misstatement would that be?
[QUOTE=TopCat]More heat is removed, that's why I'm down at 176 on the interstate and you're at 196.
My temps are 190-194 all year, which is where it should be. I guess I like the consistency of my engine temps within a few degrees instead of varying all over.
Ugh...Nevermind...I stated all my reasoning on that before
Old Apr 27, 2005 | 02:33 PM
Av8ter's Avatar
Av8ter
Good for you if thats where you want your engine to be operating, although I dont agree with it. I could see where 180 would be much easier for the radiator to keep stabilized, especially with decent outside temperatures.
If thats true, then youre the first ive ever seen or read about that has gotten that low and I wonder if that was a stabilized temp going down the road? And how would you explain how everyone else seems to be running around 15-20 degrees higher while cruising on highway?
Old Apr 27, 2005 | 03:15 PM
Dan_the_C5_Man
As stated earlier, that sub-160* temp is dependent on the outside air temp.. I would agree I'm not going to get below 170* w/ a 160* temp stat dunring the middle of summer.
From what I've read over the last 2 years, 180* is the "magic" number as far as power production goes.. I could be wrong..
Old Apr 27, 2005 | 03:57 PM
  #33
Special K's Avatar
Special K
Old Apr 28, 2005 | 06:49 PM
  #34
Dirty Howie's Avatar
Dirty Howie
Uh, yes and no. This could be misunderstood as meaning that the engine won't be able to cool because you have too much coolant flowing through the radiator. Let's make it clear, if you increase flow of either component (air or coolant) you will increase cooling. It's basic thermodynamics that correlates heat transfer to mass flow. More heat is removed per unit time, e.g. BTU per minute, through the radiator at a higher flowrate through the radiator.
The difference is that the temperature leaving the radiator will be closer to the temperature leaving the engine, e.g. Temp into radiator = 174 and temp leaving is 168 (delta T = 6F). Bonus: the air temperature coming out of the radiator will be no higher than 174 F.
Nevertheless, the temp out of the radiator is still 16F higher (184 vs 168) and the engine is kept hotter.
A great disadvantage for a 192F stat: if you run the car hard, the water in the engine is already at 192F and has less cooling capacity than my water at 174F (the delta T between the head temp and the cooling water temp, as well as the flow rate, dictates the cooling rate of the head under load and since flow rate is constant, my 174F will be able to draw more heat out of the head quicker). The heat soak in the head will lead to detonation and KR by the PCM, reducing performance and increasing NOx, i.e. decreasing performance and increasing emissions.
True, sorta, but that's not the point. We don't want 160F coolant, we want 175-180F coolant to minimize wear and increase performance, albeit sacrificing some in emissions (from startup to 174F temps since the cats don't work well until they heat up).
For clarification also to those reading this, the t-stat is on the downflow side of the engine and there is a lag between the time the coolant heats up and the time the t-stat 'sees' the hotter water and opens up further to increase flow to the radiator. It is not instantaneous. There is design work by the large car manufacturers to incorporate an electromechanical valve to work quicker and closely maintain engine temperatures to eliminate KR due to heat buildup in the engines, but the expense and reliability issues associated with the design currently preclude its use in mass produced cars.
You must not have enough experience with 160 stats because that's not true. As a matter of fact, my temperature fluctuated WAY more with the stock stat than with the 160. Considering how consistent my temps are, it wouldn't surprise me if the engineers designed the LS1 to run at 175-180 with a 160 stat, knowing that hot rodders use 160s all the time.....but maybe I'm justifying myself, or giving them too much credit, or both
They only complain if they don't do their homework and don't listen to the many members of the forum that tell them they want @ 180F for top performance, longevity, etc.
Plain and simple, heat kills and the LS1 should be run as cool as effective, and 180 pulls less KR and is hot enough to burn condensation and fuel out of the oil and hot enough to reach the clearances designed into the components made of dissimilar materials. Either experiment with a stock stat to get to 180 like Dan or go the simple route and put in a Hypertech 160 and get 175-180 all summer long. Note: if in cold climates, winter driving will necessitate switching back to the stock stat to maintain proper operating temps.
This is some of the best dang explaining on this topic to date!!!
But if you read all this.....you might understand why I still have my 160 stat sitting in my garage and not installed in the car...I can't make up my mind........
Old Apr 29, 2005 | 10:43 AM
  #35
TopCat's Avatar
TopCat
Default Coolant = 160F to 210F + Oil = 200F = Fine.
Read following link. Coolant temp is not so sensitive for engine survival. Coolant temp primarily affects emissions and performance. Oil temps affect durability and performance. If coolant is "cool" between 160 to 210, the average would be 185.
10 Tips for Engine Survival
Now, engine component clearances have been used to argue maintenance of certain chosen (favorite) temperatures. The coefficient of thermal expansion of aluminum and cast steel are 13.7 x 10e-6 in/in/degree F and 8.3x10e-6 in/in/degree F, respectively. For each linear inch of material, a ten degree difference in temperature would yield the following changes:
1" bar of Aluminum would shrink/grow .137 thousandths of an inch or 0.35 microns (a human hair is 60 microns)
1" bar of steel would shrink/grow .086 thousands of an inch or 0.22 microns
The difference, or gap, that would be created between the dissimilar metals is .14 microns per inch per 10 degree difference.
Aluminum pistons in steel sleeves. Approximate diameter of both in an LS1(for simplicity) is 3.9 inches. Assuming linear expansion, the difference in expansion between the two, at a 10 degree difference, would be 3.9 x 0.14 microns = 0.546 microns = 2 ten-thousandths of an inch (.0002 in). I believe that would fall within the blueprint tolerances for the engine component dimensions. I can't see the tolerances being in a range of 1 to 2 microns (4 to 8 ten-thousandths of an inch (.0004 to .0008). Standard oil filters pass particles that are 40 microns in size.
I prefer lower temps to give me some thermal inertia for heat when I stomp on the throttle; my coolant temps have climbed to 205-210 after a hard mile run on the interstate. However, my oil temps don't get above 200.
When running the stock stat my oil was hotter to begin with (typically @ 195F) and after a nice high speed jaunt, it easily climbed over 210....same with the tranny fluid, ended up at a higher temp.
As mentioned in the posted link, 200 is as high as you want to go with engine oil. Also, I'd run into KR and accelerated fluid oxidation and material corrosion with the higher temperatures.
This might be enough information to help those sitting on the fence decide.
Old Apr 29, 2005 | 09:29 PM
  #36
Dirty Howie
Well now you did it. You pushed me off the fence (also input from Evil Twin in some PM's he sent me)
My oil temp regularly run 210-217 during normal driving while my coolant stays 192-196. So assuming my oil temps are reading accurately I am going to try the 160 stat I have sitting around and see if I get lower oil temps. I have had some timing taken out of my tune due to mid range RPM pinging...hopefully from this heat issue. Then I can put back the timing.
Thanks for all the great info and food for thought!!
