Manual Fan Switch
Apr 25, 2005 | 01:55 PM
Manual Fan Switch
Has anyone installed a manual cooling fan switch that will override the PCM? I'm going to install a switch to be used when racing.
I would like to know the wire gage and how you tied into the relays.
Thanks,
Bob
Apr 25, 2005 | 05:00 PM
Cruise-In VII Veteran
I would also like to know! Will use mine when hood is up in pits to cool motor.
Apr 25, 2005 | 07:39 PM
Hope this helps
Apr 25, 2005 | 07:51 PM
Is a 99 Vette different than Camaro??
Apr 25, 2005 | 08:40 PM
Quote:
Originally Posted by IDntSpd
Thanks Kevin. I will look in the morning and see if it will work.
Bob
Apr 26, 2005 | 09:27 AM
I have done it before on the Vette. I believe the Camaros are different. PM me your email and I can send you a wiring diagram.
Apr 26, 2005 | 06:28 PM
Quote:
They are different!
PM sent.
Thanks,
Bob
Apr 26, 2005 | 06:33 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you dont want to tune your PCM, I have a Hayden Adjustable fan controller that I purchased and didnt use. I will sell it VERY reasionable!
If your going to install a switch, just install this at the same time and you can change your coolant fan on and off settings
Bill
Apr 26, 2005 | 06:42 PM
Bill
PM sent. Thanks.
Bob
Apr 27, 2005 | 09:11 AM
Guys I had a couple requests for the fan wiring diagram. I posted it under my gallery on the forum. The picture is pending approval. Check there.
Apr 27, 2005 | 09:58 AM
Thanks Chris. I appreciate the info. Accidently deleted your PM. Can you resend?
Bob
Apr 27, 2005 | 10:30 AM
