what heads and cam?
what should I buy?
I read a lot of thread about this.
Patriot has a lot of guy complaining but I never really read one guy that says "this product sucks and I had problem" but most of the time this is guys that know someone who...bla..bla
Are the Patriot heads really worth the money.
Then should I go for the 5.3 or the LS6 with the big valve,
I also check their cams and they have only two different one. the first one does look agressive enough for me the second one look way too agressive.
I think I should look for 228/230 112LSA with a lift of .585"
I'm lost and hesitate all other competitors have much higher price plus most of the time you won't have news heads but need to send yours back.
People have had problems with Patriot's LS6 style. Everyone will tell you to stay away.
Get MTI stealth cam and AFR 205 heads!
If yes they did a mistake but took care of the problem under waranty
WOW. Love that cam. Did not lose any bottom end and gained a bunch in midrange and up to the limiter.
Question: Did you move your rev limiter up from 6200 stock setting?
___________________tea 1.5rev2_____________________afr205
_________________Average of last3__________only 1 test in database
.100________________69.36_______________ __________ __64.1
.200_______________139.97_______________ __________ _140
.300_______________202.4________________ __________ _203.4
.400_______________251.4________________ __________ _250.1
.500_______________289.86_______________ __________ _282.9
.550_______________303.9________________ __________ _296.5
.600_______________315.83_______________ __________ _303.4
You doubt that Ike.... here is some fact Ike..... now please back up your OPINION Ike....
As a matter of fact Ike, the numbers from the AFR head are better than AFR actually claim on their site and the TEA head still out flows it. AFR is a nice head but it aint all that, especially for $2,000+.Taking it a step further Ike, you and I have very similar setup's, the only difference is you have $2,000+ AFR heads and I have a set of 3 year old cnc heads, my rwhp is 410 and rwtq is 382, my heads cost $1,200. Maybe I'll go to Disney with the $800 I saved.
