Headlights do not come up?
Old Apr 29, 2005 | 09:55 AM
EStreeter's Avatar
EStreeter
Default Headlights do not come up?
I have noticed that sometimes both headlights to not pop up when the lights come on with the twilight control. If I reset the twilight to "off" and manually turn the lights on and off a couple of times they will both come up. I can then reset the twilight to on and everything is fine for a while. Is this a problem in the making, an adjustment is needed or just a quirk. Driving me
Old May 17, 2005 | 09:36 PM
speedydog5's Avatar
speedydog5
Me too!!!! help somebody
Old May 17, 2005 | 11:55 PM
Touch of Fast's Avatar
Touch of Fast
me three....
Old May 18, 2005 | 11:03 AM
magredZ51's Avatar
magredZ51
Some head lights are easier to get to pop up than others.
Old May 18, 2005 | 11:28 AM
~SPEEDY~'s Avatar
~SPEEDY~
Old May 18, 2005 | 11:36 AM
DickieC.99's Avatar
DickieC.99
Have any of you checked your battery connections? I had a similar problem and it ended up just being a loose connection. Hope this is all.....
Old May 18, 2005 | 01:31 PM
ghostmech's Avatar
ghostmech
I had the same problem. First check your HL control fuses and ohm check the HL control moduel (I found all was good). The only thing left for me was the multi switch on the steering column..... I changed it and my lights worked as advertised.
took about 3-4 hours..not that hard really
To Headlights do not come up?
