need help asap
Old Apr 29, 2005 | 12:38 PM
pdd000's Avatar
pdd000
Default need help asap
http://www.picturejudge.com/memberpi...es/Picture.jpg
i hooked up my battery today for the first time all winter and my directionals wont shut off. even with the key out of the ignition. i tried the directionals and they dont work at all. all i get is the directionals on at all times. help!!!!!
Old Apr 29, 2005 | 01:56 PM
FRCTony's Avatar
FRCTony
Emergency flashers?
Old Apr 29, 2005 | 02:27 PM
pdd000's Avatar
pdd000
no there no blinking-just on all the time
Old Apr 29, 2005 | 03:50 PM
pdd000's Avatar
pdd000
also getting code c1232 on the dic
my batt went dead after 3hrs
Old Apr 29, 2005 | 03:52 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I think you have a bad battery screwing with the computer.
Old Apr 29, 2005 | 05:15 PM
pdd000's Avatar
pdd000
battery is good. its a 6 month old altima yellow top
Old Apr 29, 2005 | 05:33 PM
2KVetteMan's Avatar
2KVetteMan
I honestly don't know if this will help or not. But I had one side working and one side not and the bulbs were good and there was no short or fuse blown.
Down by the brake and clutch pedal on the firewall there is a big black button of some kind. I pushed that in and released it by hand. That reset my brake lights and it solved my problem.
Try and see what happens. Make sure you have the E-brake on at least. I believe that button releases the brakes.
Cheers!!
Old Apr 29, 2005 | 06:39 PM
pdd000's Avatar
pdd000
do you have a pic?
Old Apr 29, 2005 | 07:04 PM
SpinMonster's Avatar
SpinMonster
Disconnect the battery for a few minutes to reset the PCM
Old Apr 29, 2005 | 07:36 PM
JH's Avatar
JH
Do keep us posted! Weird.
To need help asap
