anyone have the LSX intake?
Old Apr 30, 2005 | 07:23 PM
Silvervette73's Avatar
Silvervette73
Default anyone have the LSX intake?
if you do, did you get the 78mm or 90mm? did it give you good results and did the car need tuning once installed? how hard was the installation? i currently have LGM headers/off road x pipe/borla stinger setup with votex ram air , and i dont know if i will gain that much more hp with the LSX intake. car was dyno tuned before header installation. thanks in advance.
Old Apr 30, 2005 | 10:55 PM
boblackhardtop's Avatar
boblackhardtop
if it's stock cube don't bother, LS6 is good enough.
Old Apr 30, 2005 | 11:16 PM
BlownV6's Avatar
BlownV6
Exactly. Waste with stock cubes
Old May 1, 2005 | 08:25 AM
Silvervette73
i was planing on doing heads and cam package from mti later on, would it still be a waste to go for the LSX? it will still be same cubes, just ported haeds and a cam. and how easy is it to put on a diff intake? will i need a tune? wah am i looking to gain hp wise. thanks again.
Old May 1, 2005 | 09:07 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Read this review and you will stay with the LS6...
http://www.gearchatter.com/viewtopic10974.php
Old May 1, 2005 | 09:09 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
FAST 78 is worth 10-12 RWHP over an LS6 GM intake...
FAST 90 is worth 15-20.....more if the FAST intake is ported.
Also, you could see an additional 4 RWHP with the 78 set-up if you run a ported stock TB, assuming whoever did the porting knew what they were doing....
I would say the gains are worth it....it's just a matter of what your willing to spend for HP versus dollars. Also, do a search....there is alot of info in this intake from previous threads.
Tony M.
PS...the gains I am quoting are on stock displacement applications.
Old May 1, 2005 | 09:22 AM
blazeone's Avatar
blazeone
My experience with the FAST intake and an LS2 TB was it gave my '04 C5 a slugish low and midrange. Engine has 224-581-112 cam with MTI2E heads and 3:42 gears. Got more peak power "only 7hp" but lost torque down low.
I think it's all in what you want, for a pure drag racing application it's the ticket. Not so sure on a street car, just depends on the old trade-off rule.
Old May 1, 2005 | 10:24 AM
Silvervette73
great info , thanks. looks like the gains are not alot from the LSX over the LS6. not worth the much xtra price. i wonder if the gains would be that much more from the LSx when i port my heads and get a cam.
To anyone have the LSX intake?
