trans cooler with fan??
has anybody tried using this setup:
B & M trans cooler with thermo switched fan?
http://www.bmracing.com/index.php?id...bcat=28&pid=75
any and all input will be greatly appreciated.
thanks,
dan
I plan on just a regular B&M cooler in front of the radiator. When I get the chance.
thanks,
dan
My cooler is a generic cooler from autozone. I paid less than $50 for it, and it keeps my tranny oil under about 175 almost ALWAYS. No fan, just mount it where ever you want to, there are several spots, some being more efficient than others. Don't waste your money on that one.
A long time serious drag racer told me that tranny fluid can't really be too cold (within reason). I don't know, but 90 sounds fine to me.
If you don’t go on a road course then either the 70273 or the 70266 would be more appropriate. Cost for either one is under $60. The 70273 should be plenty for a stock converter and will work pretty well with a high stall converter. Since transmissions really like to be cool the 70266 will give you an extra margin with a high stall converter.
All of these coolers are easily adaptable to steel braided lines that look better and will never leak as compared to the rubber hose and clamps method
Note: Summit puts a prefix in front of the number (AER-)
(2) Aeroquip FCM2013 –6 AN to ½ NPT male adapter (cooler)
(1) Aeroquip FCM1022 –6 AN 45* swivel hose end (trans return line)
(2) Aeroquip FCM4032 –6 AN 90* swivel hose end (cooler)
(1) Aeroquip FCM4042 –6 AN 120* swivel hose end (radiator)
(2) Aeroquip FCM2108 –6 AN to 5/8 –18 inverted flare adapter (radiator & trans return line)
(1) Aeroquip FCA0606 –6 AN AQP racing hose, 6ft.
(1) GM # 442338 (or similar) 5/8 –18 inverted flare female union (trans return line)
Aeroquip website: http://www.aeroquip.com/pages/lit.html
B&M uses ½ NPT, female fittings on their coolers, others may be different.
It may be wise to cover up the steel braided line with some of that corregated split plastic wrap as the steel braid can be very abrasive on whatever it contacts,
GM used the 5/8 –18 inverted flare fittings on transmission lines, through at least 2000 and probably later, then it was changed to something else but I can't recall what it is
