1/2 quart or not?
Old May 1, 2005 | 06:11 PM
Rou-Rou 03's Avatar
Rou-Rou 03
Default 1/2 quart or not?
I`m going to be running hot laps on a 2 mi road course with 11 turns. Have heard it is good to add 1/2 quart oil. My question is if I add the oil will it hurt to drive the 200 miles home since I will not be able to drain it out till I get home?
Old May 1, 2005 | 06:14 PM
Shylor's Avatar
Shylor
Get yourself one of those pumps that remove oil through the dipstick. But I doubt after your road course run, you will be a 1/2 quart up. Most likey you will need to add oil.
Old May 1, 2005 | 06:17 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
won't do anything
Old May 1, 2005 | 08:53 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
No harm leaving it in there, it'll just burn off.
Old May 1, 2005 | 10:19 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I've always put a full 7 quarts in for daily use with no issues.
Old May 2, 2005 | 03:26 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Buying a special pump to pump it out of the dipstick hole?!?
Old May 2, 2005 | 04:13 PM
3XBlack6spd's Avatar
3XBlack6spd
It is actually recommended to add a Full quart more for racing. It will not hurt you in any way
Old May 6, 2005 | 11:56 PM
SLPRC5's Avatar
SLPRC5
Yep, says so in the owners manual to add 1 qt for racing do to slushing on turns and banks...
To 1/2 quart or not?
