Heads UP: OEM sparkplug durability issue.
Old May 1, 2005 | 08:44 PM
magredZ51's Avatar
magredZ51
Default Heads UP: OEM sparkplug durability issue.
I replaced my oem sparkplugs from my '01 coupe @ 23000 miles.
Five of the eight plugs removed were missing the plat. hockey puck
on the ground electrode. The gap measured .068 w/o the puck.
My pcm never thru a code. The new plugs are NGK TR55 gapped
@ .059. Also replaced the wires with GM Performance Parts LS1,
" 8MM Red Wires ". I destroyed 4 of the 8 old wires when removed,
PITA. Haven't driven, cuz driver seat is @ the trim shop, but
Ashley starts and runs strong. Can't wait to test drive.
Anybody else have the same issue with OEM plugs?
Old May 1, 2005 | 09:38 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
everybody has had the same issue with the factory delco plugs.
I also installed the TR-55's.
Old May 1, 2005 | 10:17 PM
6Speeder's Avatar
6Speeder
Same story, gap was 70 thousands after 20,000 miles.
NGK TR-55's here also.
Old May 2, 2005 | 12:30 AM
debmwb's Avatar
debmwb
I understand that the 04's have the Delco Iridiums installed. Any issues with those?
Old May 2, 2005 | 01:21 AM
carnut108's Avatar
carnut108
I have an 04 and would also like to know what plugs I have.
Old May 2, 2005 | 02:57 AM
Vette 4 Fun's Avatar
Vette 4 Fun
Old May 2, 2005 | 03:00 AM
carnut108's Avatar
carnut108
well, I looked it up myself. The 2004 LS1 have Iridium
plugs, good for 100,000 miles. ( they say) I've got 10,000 on mine with no problems.
Old May 3, 2005 | 11:32 PM
Wisdom's Avatar
Wisdom
Well, I'm curious about this. I've got a 2004, so the plugs are hopefully iridium and will last. But with the older plugs - does the gas mileage drop after the pucks disappear? Is there any noticeable effect that someone can feel that will make them look at the plugs? Most of the posts I've seen on this start out with someone stating that they removed their plugs and the pucks were gone... but what caused them to remove the plugs in the first place?
- Wisdom
Old May 4, 2005 | 12:41 AM
Richin Chicago's Avatar
Richin Chicago
- Wisdom
Mine had a slight miss whenn I was at the track and had a long pull up the front stretch.
Old May 4, 2005 | 04:38 AM
markcz's Avatar
markcz
- Wisdom
I replaced my plugs with NGK Irridiums at 17,000 miles, partly due to knowing about the puck issue, partly because I'm a modaholic, and partly "just because". I was missing 3 of the 8 pucks. The only noticeable change with the new plugs was a MUCH smoother idle.
Old May 4, 2005 | 08:20 AM
SGT. PYLE's Avatar
SGT. PYLE
That's It!!!! You just pushed me off the fence. I have been contemplating changeing out the plugs and wires for quite a wile now but I have read some post's that say you really dont need to do this. I am about to place an order for NGK55's and MSD 8.5 Super Conductor wires!!!
Old May 4, 2005 | 09:26 PM
magredZ51's Avatar
magredZ51
Default Wisdom's question.
I changed my plugs for these reasons.
1. Read on forum regarding pucks missing on oem plugs with only 20000 miles.
2. Bought car used w/ 21000 miles, was curious about cylinder condtion.
3. Had occasional starting issue.
4. Car idled at 750 rpm. Spec for 2001 M6 is 800 rpm.
Five of the 8 plugs were missing pucks. Plugs read good. Car starts and runs good now, and idles at 800 rpm.
I changed the wires cuz, I broke half of them.
Old May 4, 2005 | 10:33 PM
Wisdom's Avatar
Wisdom
Thanks for the extra insight. My 2004 A4 idles around 550. At one point I considered changing plugs, now I've got to verify that the irridiums are there like Carnut says. According to the DIC, I get ~32 mpg at 40-50 mph, which I think is pretty good - it's much better than the wife's 6-cylinder Sport Trac! I would think that if the plugs were going bad then my mpg would start to fall too. And I'm one of those that tracks mpg's for no particular reason!
- Wisdom
To Heads UP: OEM sparkplug durability issue.
