Crankshaft Balancer slipped loose. Remove the engine??
Old May 2, 2005 | 06:14 PM
mattwolf's Avatar
mattwolf
Default Crankshaft Balancer slipped loose. Remove the engine??
The crankshaft balancer on my 97 Vette has come loose and moved forward about an inch. The local dealer said they have to remove the entire engine to fix it. This doesn't sound right.
Also, I understand the balancer has to be put back into it's original position, but if the balancer has slipped loose and changed rotational position relative to the crankshaft, how do they determine it's original/correct position if the two are not "pinned" or "keyed" together?
I hate dealers, but I don't have a lot of choices here. Do they really have to pull the entire engine??
Matt
Old May 2, 2005 | 07:18 PM
FRCTony's Avatar
FRCTony
ttt
Old May 2, 2005 | 07:21 PM
lively14's Avatar
lively14
I have the same problem on my '99 right now (but I discovered it the day before I left for Iraq, so it'll have to wait until I get back). I have the service manuals (in 3-phonebook thick volumes), which details exactly what you have to do to change it. You have to remove quite a few components to get at the pulley, but far less than you would if you were to remove the engine.
Even if they do not have to remove the engine, however, the cost for labor will still be rather steep. I was quoted $1200 for labor alone, so I just opted to just let the car sit for a year and fix the problem when I do my head/cam/headers/intake manifold swap when I get back.
Unfortunately, I do not have the service manuals with me here (and can't tell you exactly what components need to be removed in order to get at the pulley), but there was another forum member who offered some good advice on it. He also suggested pinning the new pully in order to prevent the same problem from happening again in the future. I wish I could remember his name, but I can't. Hopefully he'll respond to your thread.
Old May 2, 2005 | 07:26 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Either fix this yourself or take it to another dealer.. No way in hell you need to remove the engine to fix a loose / broken crank pulley.
Old May 2, 2005 | 07:46 PM
Dope's Avatar
Dope
Resident moron
You have to remove a bunch of stuff but certainly not the engine and certainly nothing major.
You don't have to put it on in the same orientation either. However, if it's spun on the crank then you should probably either get a new one or pin the crank, cuz it's just gonna happen again.
Use the opportunity and buy an ASP underdrive one instead?
Sounds like the shop wants to rip you off. Find a reputable shop, or a local board member who can help you, or do it yourself. It can be a pain in the *** without the right tools. Especially since there is a specific re-tightening procedure which requires a lot of torque (I think you have to torque the old bolt to 240+ ft/lbs). Plus pinning the crank can be a bit of a pain too.
Dope
Old May 2, 2005 | 07:51 PM
juiced's Avatar
juiced
all you have to do is loosen the abs block, unbolt the steering colum, slide the rack over and it's pretty simple about 3 hours worth of work with some air tools
Old May 2, 2005 | 11:39 PM
lost's Avatar
lost
You dont remove the engine anyway you remove the body from the engine chassis assembly, then you still have disconnect the steering rack. If there was a certain way the balancer had to go on they would have keyed the nose of the crankchaft...Omg I'm talking like a mexican. And tuners would be charging $1500 labor to install a cam. Get a pin kit and an ASP pulley while your at it.
Old May 3, 2005 | 01:41 AM
lively14's Avatar
lively14
That picture just looks SO $$$$$$....two mechanics just standing there...hurry, WORK!!!
Old May 3, 2005 | 01:58 AM
blackbelt's Avatar
blackbelt
then the fun part of removing the pulley the rest of the way unless your lucky enough to have it slide off. Its not fun but is pretty easy to do. Juiced and I have done it several times and like he says we can do it in like 3 hours now.
Old May 3, 2005 | 08:55 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Default not to hijack your thread, but a related question
What are the current options for a balancer? I'm not a big proponent of underdrive pullies, so I will probably use a stock damper when I do my H/C job. Just wondering if there are any new offerings on the market....
Old May 3, 2005 | 10:44 AM
corvettebob1's Avatar
corvettebob1
Use the ATI super damper and pin the crank while your at it!
Really its not that difficult, just remove the rack and the stability control unit if you have it.
Then use red loctite on a new bolt and torque to 100lbft or more and your good to go.
If you pin the crank there is NO reason to use the torque to yeild method!
Old May 3, 2005 | 02:08 PM
IM QUIKR's Avatar
IM QUIKR
But you will need a new crank/balancer bolt. I found it was cheaper at the Cadillac dealer than Chevy . Check on the FI section for a crank pinning kit. Some of the SC tuners will rent or loan you one to use.
Quicksilvers pinning slide show.
To Crankshaft Balancer slipped loose. Remove the engine??
