ET Streets burnout time
Old May 4, 2005 | 01:18 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default ET Streets burnout time
Is there an optimum time for your burnout with ET Streets? Of course you can underheat them but can you overheat them where it would be counter productive?
Old May 4, 2005 | 01:38 PM
Special K's Avatar
Special K
I think only you can determine that Jason. My car will run 12.7's and I don't have to heat them at all. Just a dusting. I do not have a traction issue.
I think it depends on power and stick or auto. Same goes for air pressure.
You may get some insight from someone with a comparable car. Then what about track conditions. They would have to be comparable.
Old May 4, 2005 | 01:40 PM
Cajundude's Avatar
Cajundude
Just curious, cause me likes to smoke 'em and I think it will be only worse since I intsalled the line lock over the weekend. It will be too easy not to!
Old May 4, 2005 | 01:46 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I do a moderate burnout the first run, then just until smoke begins to show on preceding runs....I usually get 1.64-1.68 60' times...
Ron
Old May 4, 2005 | 01:49 PM
Cajundude's Avatar
Cajundude
Ron
This is right where I was at as well. I think my best was a 1.62. I just changed the exhust to LGM LTs and Borla Stingers so I can't wait to get back to the track. I may go for trophy night, tonight! Weather looks good so far. The only problem would be getting my car dirty after cleaning it up for this weekends crawfish event.
Old May 4, 2005 | 01:53 PM
Cajundude's Avatar
Cajundude
Corrected, 1.636.
Old May 4, 2005 | 03:37 PM
new vetter's Avatar
new vetter
Just enough to get deep heavy smoke rolling off the tires and release the L.L. and let the car roll out of the burnout.. Good for 1.6 at a slippery track.
Old May 4, 2005 | 04:33 PM
Phil97SVT's Avatar
Phil97SVT
I wait until I see smoke, usually pretty quick @ 6k and 2nd gear. Stage the car in the groove, activate the nitrous, hold @ 6-6800 depending on track conditions.... 1.40-1.43's all day long
Phil
Old May 4, 2005 | 05:57 PM
robz's Avatar
robz
Some believe you can overheat them, but I haven't seen adverse effects from doing big burnouts all the time. I tend to do longer burnouts then most especially on colder days.
Old May 4, 2005 | 09:52 PM
Dr.Ron's Avatar
Dr.Ron
Rob, the last time I saw you , the only thing that burned out was some excess gas in you tank on the way TO the track!!!!
Ron
PS-Didn't I PM you somewhere??
Old May 4, 2005 | 11:30 PM
simpleman68's Avatar
simpleman68
Phil
1.4 60's Now that's what I'm talking about!!
I'll be pleased to get into the 1.7's with my new DR's
Niiiiice launching Phil
Scott
To ET Streets burnout time
