My LS1 Valve spring testing results....
Old May 4, 2005 | 02:37 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default My LS1 Valve spring testing results....
As some of you may remember I broke an Exhaust valve spring on my stroker back in October of last year. I replaced both intake and exhaust springs on the #6 cylinder only as I did find a factory defect causing a stress riser and an untimely spring break( Of course hitting the rev limiter doesn’t help either )
I finally had a chance to test the old Pioneer intake spring that did not break and a few of the new Patriot Performance Gold springs. (Thanks to Steve & Rob at Abacus) The results would tell me if after 7K hard miles I need to replace all 16 springs or just the 2.
Used 7K+ mile Pioneers from Cartek’s 4X heads
Installed Height 1.800" = 120lbs
Valve Spring Open Pressure 1.200" = 370-375 lbs
Brand spanking new unused PP Golds (Note, these will lose ~10% strength after break in)
Installed Height 1.800" = 145 lbs average
Valve Spring Open Pressure 1.200" = 375 lbs average
Based on my results and continued good performance I WILL NOT CHANGE ANYTHING ELSE AT THIS POINT
And for some good FAQ on the above here is a good place to go.
http://www.cranecams.com/?show=valveSpringsFAQ
Old May 4, 2005 | 04:27 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
It's good to see your orginals are holding up well. I have about 2500 miles on my comp 921's. When I get the time I am going to check them all to make sure they are holding up as well.
I would rather not go through a dropped valve due to a faulty spring
