missing power w 422
200 155.9 136
300 212.3 171.9
350 235.5 186.3
400 258.8 193.4
450 280.3 202.4
500 293.6 213.2
550 301.9 218.5
600 311.8 227.4
Cam = 248/248 .621/.621 @ 110 + 2
Exhaust = 1 7/8 Kooks w ORP & GHL's
LS6 intake
~ 11.5:1
The numbers above are from several years ago on the 346.
The first run was at ARE at time of build with limited miles on motor and TPIS 1 3/4 headers. 475 rwhp/467 rwtq
The second run is after new springs/valves/guides/retainers/etc, 1 7/8 kooks, tuning at Speed Inc and ~ 3900 miles. AFR rock solid at 12.5ish and no knock. 484 rwhp 459 rwtq
Obviously, a FAST 90 setup would help, but IMO (and others) it is still way down, especially tq wise from other 7.0L motors.
Any idea's? It almost looks like it is in a valve float condition, which still wouldn't explain the low tq...and I doubt it would get the ~ 30-40 rwhp it is down.
On a happy note, I did pick up 4 mpg on the way home from Chicago, avg 24.8 . The tune is much smoother.
http://www.ls1tech.com/forums/showthread.php?t=317867 if you want to see the dyno runs
Looking at the AFR on the second sheet, you do drift a little rich as the rpm's go up. You might pick up ~5hp there if you go to 13:1 but you might lose some torque also.
I would say if all else is fine the heads could be larger in terms of flow numbers. What does the car run like at the track?
