BIG HELP? Electrical
Old May 7, 2005 | 07:51 AM
ryentee's Avatar
ryentee
Default Help Please? Electrical
I just finished up on my stereo install during which time the battery was disconnected. I reconnected the battery and found out it was dead, so I pulled it out of the car and charged it up overnight. Went to connect it this morning and from the passenger side footwell I hear this buzzing noise comming from, I assume the cars computer(silver box with all the wires going to it?). I waited a few minutes and connected the battery again, but this time no buzzing noise. Went to go start the car and all I get is a clicking noise, not like the starter clicking noise, but an electrical clicking noise. All other electrical functions in the car works fine just will not start. I just spent the last 3 hours going over all my connections I made for the stereo to make sure there was nothing that came loose and that might be grounding. I am going home in a couple hours to check to see if there are any codes.
Any help would greatly be appreciated!
Old May 7, 2005 | 08:05 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmmmm....so lemme get this straight....battery was ok before you removed it???
and electrical guru is Bill Curlee..hopefully he will pop-in and help ya out
Old May 7, 2005 | 08:14 AM
ryentee's Avatar
ryentee
The battery had a little power in it when I started the install, but not enough to start the car. It has been stored for the last 5 months.
Old May 7, 2005 | 10:20 AM
ryentee's Avatar
ryentee
Please help. Anybody out there with any idea's? I was able to get the codes that it threw but I have no idea where to start.
B0505-H,B0508-H,U1096-H,U1040-H,U1060-H,U1176-H,B2262-H,B2264-H,B2282-H,B2284-H,U1064-H,B2263-H,B2265-H,B2283-H,B2285-H,U1255-H,B0851-H
All of them show history and none are current. I did not know if I should delete them and than try to pull them again?
Old May 7, 2005 | 10:36 AM
gredmer's Avatar
gredmer
I wouldn't do anything until I installed a NEW battery.
Old May 7, 2005 | 11:00 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Default similar problem
i never did figure it out, i just replaced the battery(and i'm an electrical contractor, go figureLOL)
Old May 7, 2005 | 11:44 AM
Special K's Avatar
Special K
Have you checked the battery with a volt meter or hydrometer? That would be the first step. You have to determine if the battery is good. If using a volt meter wait a few hrs after charging or you'll get a false reading.
Old May 7, 2005 | 11:46 AM
pewter99's Avatar
pewter99
all the codes are most likely due to low battery......do you have another vehicle you can hook it up to not necessarily to jump start it but to see if you can turn the car on and off and back on without throwing codes??? I got $50 that says new battery will cure your problem
Old May 7, 2005 | 01:23 PM
ryentee's Avatar
ryentee
I tested the battery and it shows a full charge. I went out and bought new battery just for the heck of it and it is doing the same thing. As soon as you turn the key to the on position the silver box in the passenger footwell buzzes like an alarm clock.
Should I clear the codes and retry starting it and see if the codes change. I was curious about the codes because they all show in history and nothing current?
Old May 7, 2005 | 01:53 PM
pewter99's Avatar
pewter99
Ok well you have crossed over the realm of any help I can offer so heres a TTT for ya...get with Bill Curlee...good luck
Old May 7, 2005 | 11:43 PM
ryentee's Avatar
ryentee
After all my sweating today and thinking my car was dead the issue did turn out to be the battery. The new battery that I bought was actually bad. They gave me another one. Dropped it into the car and it fired right up.
Thanks for everyones help. This forum is great
Old May 8, 2005 | 12:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most likley it is not the batteries. You probably have a bad or defective battery cable. Often the OEM AC Delco side post battery will leak acid and it spills into the battery cable terminal end. The corrosion makes a bad connection. The buzzing relays indicate that there was NOT enough battery voltage to allow the normaly energized relays to energize.
If I were you I would remove and examine each battery cable , clean the connection with a wire brush, spray it out with brake parts cleaner, followed by a good doush with WD-40 and reassemble. Tighten the battery cables to 11 FT/LBS
BC
Old May 10, 2005 | 11:10 AM
ryentee's Avatar
ryentee
Thanks Bill. I followed your directions and after 3 days of driving everything is great!!!!!
Old May 10, 2005 | 11:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Very Cool!! Enjoy your summer! See ya on the forum.
Bill
To BIG HELP? Electrical
