Performance brake lines other then SS???
Old May 7, 2005 | 10:15 AM
Redline Motorsports's Avatar
Redline Motorsports
Default Performance brake lines other then SS???
I have had it with the SS lines I put on a few months ago. Constant codes 1225 and 1226 for excessive wheel variation. Everything checks out and I even replaced both harness connectors, one wheel speed sensor and grounded both lines to the chassis. The more I thought about the problem it started AFTER the SS line installation. The entire EBCM checks out as well per the GM manual.
Before I put the stock lines back on the car, does anyone else make a performance line that's not stainless but with improved material??
I know this has been an ongoing issue for others as well so please update on what solved the problem......if any!
