Air Induction Grills
Old May 7, 2005 | 03:33 PM
diverman's Avatar
diverman
Default Air Induction Grills
Help!I'm trying to install the cold air grills on my 2000 convertable.The instructions included say to reach in under the head lamps to remove the three mounting bolts.With the head light trim removed I can just barely touch one. I can't see any of them.Has anyone had any experience with this install?Thanks
Old May 7, 2005 | 04:28 PM
Patches's Avatar
Patches
You can also reach them from underneath if you take out the fascia/radiator shroud screws and the air dams and closeout panels. Here's a pic of what one of the fog light shrouds you're trying to get to looks like with the mounting holes labeled. Becareful of the wire harness attached at the bottom with clips. Also, the outer mounting screw also helps hold the turn signal lamp housing so make sure you reattach that as well.
Old May 7, 2005 | 10:50 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just did a Vararam VB2 install and installed driving lights in my Z06. I removed the closeout panels under the front facia and the brake air ducts. Once you remove them, there is all sorts of room.
PM me your e-mail address and I can send yoiu some pictures.
BC
To Air Induction Grills
