hard start
Old May 8, 2005 | 05:12 PM
Jim D's Avatar
Jim D
Default hard start
Once my 99 warms up its hard to start. You have to turn the key on and off a few times, then it will start. I have changed the fuel filter, put new injectors in, I think maybe the fuel pump, any suggestions, thanks Jim.
Old May 8, 2005 | 05:24 PM
69's Avatar
69
Cruise-In VI Veteran
Sounds like it maybe a fuel line check valve (stuck open when you turn the engine off,thus bleeding down the injector manifold). This check valve keeps the injector manifold pressurized when the fuel pump is not operating (IE, you turn the key a few time pressurizing the manifold). Do a search and you should get some hits.
Kevin
Old May 8, 2005 | 05:34 PM
Jim D's Avatar
Jim D
The fuel filter has the check valve in it, and this was changed, I thought the same thing, thanks Jim.
Old May 8, 2005 | 07:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jim
Do you have any codes. The only other thing that I can think of is a temp sensor is out of range. It is most likley a fuel issue. See if you can get a hold of a fuel pressire guage and see what the fuel pressure is cold and hot.
Bill
Old May 8, 2005 | 08:55 PM
69's Avatar
69
Jim, I have a '99 and there is no check valve in the fuel filter that I'm aware off. I have looked at the Service Manual and confirmed that this check valve is a "stand alone item". Shoot me a PM with your e-mail address and I'll send you some Tech Data from the Service Manual.
Kevin
Old May 10, 2005 | 07:37 PM
69's Avatar
69
Hello Jim,
I got your e-mail and sent the data.
Kevin
To hard start
