reset oil change system
Old May 8, 2005 | 08:44 PM
batman40's Avatar
batman40
Default reset oil change system
Hello
I just bought a 1998 the car read change oil which I did the problem is the car did not have a manual with it I ordered one but in the mean time could you please tell me how to reset the system
Old May 8, 2005 | 09:09 PM
coast7's Avatar
coast7
Batman40,
Welcome to the forum...and to the C5 brother/sisterhood
With the car off (not running), turn the key in the ignition to get the DIC to light up. Then press the "Trip" button several times until the percent oil life remaining is on the readout, then press and hold the "Reset" button until the percent changes to 100% (I think it recycles to 99% and not 100%). If that doesn't work, do a search for "percent oil life remaining"...
Good luck
Old May 8, 2005 | 09:10 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
press the DIC till you come up to the % of oil life left, and just hold in the reset button for a couple of seconds till it reads 100%,
It may only read 99% but dont be concerned
Old May 8, 2005 | 09:49 PM
batman40's Avatar
batman40
Thank You
Old May 8, 2005 | 10:00 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
or pump the gas pedal 3 times with the car off (key switched to 'on')
Old May 8, 2005 | 11:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Thats the only way that works for my 2000, also.
Old May 9, 2005 | 12:52 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
I believe the above is the way recommended by GM but the other won't hurt anything if it works. Good Luck!
To reset oil change system
