Last week my car was dyno tuned and I added 3.42's and a Yank 3000 rpm stall. The car runs like a raped ape but I have noticed something odd. When I am in traffic and easy on the gas, the 2-3 shift feels like it shifts up to 3rd then quickly back to 2nd and then 3rd. Kind of a jerky hesitation. I think it is around 2200-2300 when the shift occurs. If I am really light on the gas it doesn't happen and if I am on it hard it doesn't happen. I have been told that when you are getting used to driving a car with a higher stall converter there are some quirks to get used to when you are in traffic. I was wondering if this is one of them or if it might be a glitch in the tuning.
I'd want to verify fluid level first, then tuning. If the upshift and downshift curves are very close together you can see this sort of thing. Another longshot possibility would be that you're feeling the converter lock and unlock in 3rd (3-lock-release-lock rather than 2-3-2-3). Check the same things in that case.
I did this same mod on my 2004 A4 coupe before trading for my Vert so I have some personal experience on this subject.
The A4 tranny is very sensitive to its fluid level being even a little low so make sure the garage test drives it a time or two and checks the fluid level after each test drive.
Secondly, the new gears means that you'll need to have the shift points readjusted (yes, a PCM tune) because you're hitting the rmp shift point earlier because of the lower gear ratios.
I have no quirks or issues with the high stall, I think you have tuning issues.
Good to hear. I actually hope it is a tuning issue. I talked to my tuner this morning and I am going to take it in when I get a chance. If it is a tuning glitch I am very confident he will get it corrected.
See if you have the same condition in competition mode?
If yes then make sure that your tuner has knowledge of this condition before you go, otherwise you may not get results.
I feel that there is a point were the completed 2-3 upshift loads to the point of unlocking the converter and then locking as the load is released at the end of the shift. (Exactly as you describe). I have not seen any consequences from this.
If you get the condition solved it would be nice to know how.
I had a similar problem with my SS3600 and solved it by eliminating lockup in third gear. Made all the difference in the world. Try it and see if it fixes your problem.
