Synthetic Tranny Fluid?
Old May 9, 2005 | 09:18 PM
YellowLsWon's Avatar
YellowLsWon
Default Synthetic Tranny Fluid?
Anyone running synthetic tranny fluid? Which kind and was it any better than standard fluid?
Old May 9, 2005 | 10:08 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I use Redline ATF D4 in my M6. Takes about 4 quarts. I noticed a little smoother shifting.
Old May 9, 2005 | 10:16 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Old May 10, 2005 | 05:58 AM
bluevette1's Avatar
bluevette1
Had shifting problems and changed it with Mobile1. HUGE difference! Good for engine...Good for Mn6.
Old May 10, 2005 | 09:24 AM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I'm not sure if I'm reading this right.
We now use automatic transmission fluid in a manual transmission?
Old May 10, 2005 | 09:27 AM
pburant's Avatar
pburant
Yep.
Less viscous and therefore more efficient than traditional manual tranny fluid.
-Pete
Old May 10, 2005 | 09:37 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Mobile 1 Dexron 3. Works like a charm.
Old May 10, 2005 | 10:29 AM
topless99's Avatar
topless99
amsoil, and yes i could feel the difference
Old May 10, 2005 | 01:06 PM
Wah's Avatar
Wah
Amsoil Synthetic ATF here.
Old May 10, 2005 | 04:00 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Redline D4 ATF
Old May 10, 2005 | 05:28 PM
FKING1's Avatar
FKING1
Originally Posted by RPOZ4Z
Redline D4 ATF
Me Too!
Fred
Old May 10, 2005 | 07:03 PM
2KREDVert's Avatar
2KREDVert
The synthetic tranny fluids disipate heat better. That's the biggest advantage, cooler tranny temps. About 15-20 degrees cooler using Mobil 1. No need to spend more than the cost of Mobil 1. It's about $5 a quart.
Old May 10, 2005 | 10:34 PM
SLPRC5's Avatar
SLPRC5
Same here good stuff
Old May 11, 2005 | 12:41 AM
Last C5's Avatar
Last C5
Redline D4 ATF
Old May 11, 2005 | 06:30 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I recently tried the Mobil 1. Slight improvement.
Old May 11, 2005 | 07:38 AM
TomT's Avatar
TomT
Me too and felt the difference.
Old May 11, 2005 | 07:43 AM
gsxrjack's Avatar
gsxrjack
same with me, had that royal purple oil in it and never really felt a difference, put the amsoil in and it made a significant difference in the feel...
To Synthetic Tranny Fluid?
Old May 11, 2005 | 08:49 AM
cadmanjm's Avatar
cadmanjm
Default Amsoil here too
Only 500 miles on my 2004 and the original trans fluid looked bad! After switching to Amsoil noticed a difference. I added a magnetic drain plug and also replaced the rear dif fluid with Amsoil and added another magnetic drain plug. Rear dif fluid looked OK. Now I'm 100% Amsoil and good to go!
Old May 17, 2005 | 12:56 PM
icpsvt's Avatar
icpsvt
Where do you get the magnetic drain plugs?
I'd consider doing that for my oil plug. Sounds like it'd be useful.
-Jason
Old May 17, 2005 | 07:59 PM
Nitro Junkie's Avatar
Nitro Junkie
Default Magnetic Drain Plugs
I just bought all three (engine, tranny, diff) for an upcoming fluid change. Ecklers was about $5 more than Mid America. ($37 vs. $32, shipping included)
How much fluid does it take to do the tranny and diff, and do I need any special tools?
