water pump issues
Old May 9, 2005 | 09:33 PM
corvettefreak16's Avatar
corvettefreak16
Default water pump issues
My water pump on my 97 started leaking badly on thursday and by the time i got the car off the road and shut off i had lost almost all my coolant so needless to say the car was flatbedded back to my house. I figured the problem was the mounting gaskets so i replaced those and the o-ring on the back of the water pump. I have it all back together and its still leaking. I can tell its not coming from the mounting gaskets or the new o-ring. so where could the leak be? It looks like its coming from behind the pulley. Is there another gasket behind there? Any help is greatly appreciated.
Old May 9, 2005 | 09:40 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Well.... the bad news..
You need a NEW water pump... they never really leak from the gaskets, or the "O" ring... it is leaking out of the hole they drill in the pump... to let you know the pump is bad...yup yup yup
Old May 9, 2005 | 09:43 PM
corvettefreak16
How much is a new water pump?
Old May 9, 2005 | 09:45 PM
Silvervettes's Avatar
Silvervettes
St. Jude Donor '07
Default New pump?
I assume that you have replaced the water pump. I suppose there is always that chance that a new pump could leak
Old May 9, 2005 | 09:47 PM
corvettefreak16
No i havent replaced the pump yet. I just thought it was a bad gasket or something. But i guess i was wrong.
Old May 9, 2005 | 11:01 PM
Silvervettes
St. Jude Donor '07
Default prices
I looked at three sites and it looks like a range from about $100 to $185 and the lowest priced one was a remanufactured.
Sometimes the seal in the pump just wears out or the bearing in the pump wears out. Either way the pump will start to leak. In your case I would guess the bearing went out since it leaked the coolant out so quickly.
Hope this gives you some help.
Old May 9, 2005 | 11:09 PM
LS9's Avatar
LS9
are the seals available to the public ?
I have a press and I think I could fix a pump if I had the seal
Old May 9, 2005 | 11:13 PM
corvettefreak16
What sites did you go to?
Old May 9, 2005 | 11:18 PM
Silvervettes
St. Jude Donor '07
NAPA, Auto Zone and Advanced Auto
Old May 9, 2005 | 11:32 PM
Dug02Z0679L82's Avatar
Dug02Z0679L82
Almost all water pumps I've seen have a permanent lubed bearing on the shaft in the center. I'm guessing the vette pumps are also made this way. When the bearing wears out, runs out of lube, they start to leak out the center of the shaft behind the pulley. This is the standard failure mode. Sorry you changed the o rings. Too bad the parts man didn't tell you this. He really should have.
Old May 9, 2005 | 11:41 PM
corvettefreak16
Thanks for all the help. I guess ill have to run out tommarow and get a new one.
To water pump issues
