whats up with this
Reset the average mileage and see what it shows after a few hundred miles. If it is city drving that is about what you will get. Highway is in the mid to high 20s.
LS6 manifold = good
LS6 injectors (assuming you went from 26lbsPH to the LS6's 28lbsPH flow rate) without scaling the IFR table to compensate = BAD.
IF you simple replace 26lbs injectors w/ 28lbs models, the PCM is still marinating the same injector pulse width (it doesn't know you changed the injectors), and it's dumping extra fuel into the motor..
I swapped my 26 for 28 units out of peace of mind, and to make sure I didn't run the peak injector time-on values too high with my impending mods.
If you don't want to scale the IFR table (about 9% difference.. i.e. you'll need HP Tuners, or LS1 Edit , etc.) then put the stock injectors back in the motor.
PM me if you have any other questions about this.. :cheers
