Korreck Goes With Cold Air System !!!!!
Old May 11, 2005 | 11:30 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Default Korreck Goes With Cold Air System !!!!!
http://forums.corvetteforum.com/show...9&postcount=14
Read all about it in this thread.
http://forums.corvetteforum.com/show...6&forum_id=103
Yes the man who said that there was no such thing as cold air, has now cut a hole into the radiator shroud of his 50th Anniversary Corvette, and installed a Big Mouth Air Dam which directs outside airflow directly to his oversized Blackwing air filter.
Korreck took the time to measure and cut this hole directly beneath his Blackwing air filter. He is somewhat vague as to why he chose this location
This would appear to be an attempt to forego the "unattractive option" of having his car breathe hot, underhood air as opposed to fresh, outside air..
The BOTTOM BREATHING system is said to offer more consistency in 1/4 mile elapsed times by the man himself. This after his preliminary testing results at Moroso Motorsports Park during this year's Corvette Challenge.
Dyno results are pending.......
The air dam directs outside ambient air, which is cooler than underhood air straight to his Blackwing air filter. The vendors of the air dam claim:
In Bob's case its not just cold Air , it's an increase in CFM that is directed into the radiator compartment by The Big Mouth Performance Air Dam. Then By opening the radiator shrowed you are allowing the Blackwing a 360 degree suction , but because it creates a low pressure it sucks up all the colder ambient Air that is directed by The BMAD. Intern Bob is getting more consistent runs. We all know that denser air carry's more molecules that convert into higher HP.
I could not agree more
Old May 11, 2005 | 11:51 PM
army2000's Avatar
army2000
St. Jude Donor '11
This would appear to be an attempt to forego the "unattractive option" of having his car breath hot, underhood air as opposed to fresh, outside air..
You people kill me. This is the funniest thing I've ever heard or read..http://forums.corvetteforum.com/show...6&forum_id=103
Old May 11, 2005 | 11:55 PM
90 droptop's Avatar
90 droptop
Just think, he just increased his chance of a hydrolock over a VARARAM.
The hypocrisy of it all................
Old May 12, 2005 | 12:10 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Old May 12, 2005 | 12:18 AM
'06 Quicksilver Z06
You know, the next logical step for him would be to enclose the Blackwing with a plastic cover of some sort
Guy has a Vortex Rammer without the lid.
Seriously however, I am glad to see him get the improvement that he was looking for. It is always a good thing when a modification works as intended and this seems to have worked for him form what he says he has observed. I say, Bravo.
Even if he does have to sit down to a plate of crow and gravy. It will still wash down with a few of these
Old May 12, 2005 | 07:22 AM
Special K's Avatar
Special K
EB, I can't believe you did this. I'll be laughing about this for a week, at least. And to think I told you awhile back to lighten up and have some fun. Good job.
I saw an ad for the Big Mouth and that's what got me to thinking about this mod. At 170/180 I would run in the 12.7 range. At 195 I would run 13's. I talked to a lot of people and they were as confused as I was as to what was going on.
Last week at Moroso I ran 12.92./12.94 all nght regardless of engine temp. To run faster I have to 'power brake'. I never do that in competition. I always leave from an idle for consistancy.
If I have a chance this weekend (racing in 3 events) I will try and see if the car is any faster. Fri night and Sat night are 1/8 events, so hopefully Sat morning it will be cool enough to give it a go. I would hope to see a 12.62 or 12.63.
OK, you guys have a good time with this. Just remember three things. The Vararam is bogus, no such thing as cold air (I don't have a freezer in the car) and no such thing as ram air (I don't run 700 MPH).
Old May 12, 2005 | 08:18 AM
donnyonee's Avatar
donnyonee
if you cut a hole in the shroud for cold air, and drove thru a large dense section of real cold air, say 35-40 deg. what would be the chance of getting a pneumaticlock on your motor and freezing it up?
don
Old May 12, 2005 | 08:46 AM
'06 Quicksilver Z06
It would be really interesting to know a few things regarding your runs. Among them what the DA was when you ran those times, as well as the 60ft times when you ran the 12.7s, vs the 12.9s.
You ran 12.7s without the new system and 12.9s, sometimes at the same engine temps, with it? Did you power brake to make it to 12.7?
There must be an explanation.
Also, what were your trap speeds in the two sets of runs?
Old May 12, 2005 | 09:16 AM
Special K's Avatar
Special K
To many questions. I don't want to make a job out of this.
I don't track DA. I use an HP correction which gives me good dial ins. I'll start checking DA just for you.
60' times are terrible but consistant. About 1.95. On 12.7 runs 60' were 1.90. That's my next problem to work on. May have a solution that I'll be trying this weekend. As I said before, I have to power brake to get 12.7's.
Here is data before I made the changes.
DATE4/21/04 WEATHER 75 DEG
ET SPEED RT 60 FT
12.764 107.41 0.033 1.901
12.795 108.97 0.051 1.923
12.894 106.14 0.073 1.931
13.054 104.89 0.043 1.931
13.133 104.23 0.044 1.939
13.074 105.31 0.061 1.979
Notice the spread? That was killing me.
Old May 12, 2005 | 10:08 AM
simpleman68's Avatar
simpleman68
[QUOTE=Korreck]To many questions. I don't want to make a job out of this.
Ok, just one issue here for me and then I'll leave ya the hell alone myself.
"Now let me correct your errors. I am not getting 'cold air'. I'm getting what appears to be more ambient air vs hotter air from my engine compartment."
Is ambient warmer than hot air........or coooooler?
Can you re-read your quote with a straight face and not see how silly this Johnny Cochrane monologue is?
"If the intake fits, you must admit"!
Scott
Old May 12, 2005 | 10:14 AM
Special K's Avatar
Special K
[QUOTE=simpleman68]
Scott
Just to keep peace I'll agree with you. I just get so sick of bogus claims by many of these aftermarket companies.
Maybe I do go overboard a bit, but there is nothing cold about 85 degree temps. Cooler yes, cold no.
And I was just jabbing EB about making this work. I can always use his help and do not mind sharing data.
Old May 12, 2005 | 10:16 AM
Dan_the_C5_Man
Hey, I'm just grateful that it appears Korreck has not lived up to the axiom "you can’t teach an old dog new tricks".. Seems like he is trainable after all!!
And I too hope he sees whatever improvements he was looking for.. That's the whole point of mods, right?
Old May 12, 2005 | 10:19 AM
Special K's Avatar
Special K
Ol dog. Only in body. I have the mind of an 18 yr old. Well, maybe not that bad! Let's just try and have fun and share info.
My wife is the only person in this family not trainable.
Peace.
Edit:
I'm getting worried about EB. He hasn't posted in at least 15 min.
Old May 12, 2005 | 12:10 PM
George8211's Avatar
George8211
Why stop with that little opening for the air... I suggest you that you put a 3' x 4' funnel on the front of vette. Have you tried running your air conditioning venting to your air intake box so you can get colder air in the engine ???
Old May 12, 2005 | 12:32 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Old May 12, 2005 | 01:03 PM
Special K's Avatar
Special K
Now there's a damn good idea. Just need a drip tray under the air cond, tube. I could also remove the firewall and let more heat out of the engine compt.
Has anyone seen EB? I'm really getting worried.
Old May 12, 2005 | 01:49 PM
shurite44's Avatar
shurite44
Bob you are my pal, butt damn this is funny. I am going to laugh when I come to Florida and you finally have your black wing moded to the point it looks just like a vararam on steroids.
To Korreck Goes With Cold Air System !!!!!
Old May 12, 2005 | 06:49 PM
'06 Quicksilver Z06
ET . SPEED . RT 60 FT
12.764 . 107.41 . 0.033 1.901
No doubt. If you can find some consistency in your ETs, you'll be tough to beat. Hopefully your new modification will give you that.
BTW, are you on runflats or drag radials?
Old May 12, 2005 | 07:21 PM
Special K's Avatar
Special K
BFG DR's 315. Been running 18/22 PSI. 60' should be a lot better. Going to start at 28 PSI tomorrow. What do you think?
Old May 12, 2005 | 07:26 PM
Special K's Avatar
Special K
You got a place to stay Gary? Just kidding. You know I'm having a good time. Don't see any comparison to the Vararararam. I have a great filter and it works. Big Mouth is a good way to go.
