rear fender
Old May 12, 2005 | 04:55 PM
jay50n's Avatar
jay50n
2nd Gear
Default rear bumper
can anyone show me a link (with pics) on how to remove my C5 back end fender?...........thank you in antici..........pation
Old May 13, 2005 | 12:32 AM
SpeedyZ's Avatar
SpeedyZ
Do you have a coupe, vert or FRC? Coupes and vert just unbolt. FRC are a PITA. Factory says you cut them in half, but normally you don't have to.
You basically (for coupe and vert) remove the tail lights and reach through the tail light holes and remove the nuts that holds the fender to the rear cover. Remove the inner fender. Then remove all the bolts inside the door well, then across the top and it should come right off. If if is the left side just remove the screws about the gas filler and leave the filler hanging on the car. The best I remember there is one hard to see in the gas filler.
The problem with the FRC is due to GM engineering you can't get to 5 of the screws because they glue the top of the car on over them after they put them in.
PM me if you need more details, I probably have (or can get) photos.
Old May 13, 2005 | 02:23 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I GOT JIPPED!!!!! I didnt get a rear fender... J/K
Do you mean the rear quarter panel? or the rear bumper?
Jeff
Old May 13, 2005 | 12:09 PM
jay50n's Avatar
jay50n
2nd Gear
i meant the rear bumper...........lol
and if anyone has pics then i would be so very gratefull.
the reason i need to do this is that a dealership did some work on it and now i have a leak and need to pull the rear off to fix it.
To rear fender
