Need help!!!
Old May 14, 2005 | 01:42 AM
D stock 1's Avatar
D stock 1
Default Need help!!!
Just finish installing my new exhaust, but my car won't start. It seems to be the battery, but once I turn the key everthing shuts off.
After a minute or two it starts to make a clickin noise and the lights slowly come back to life. It sound like a shortage somewhere in the car. Can somebody help?
Old May 14, 2005 | 01:54 AM
yellow01's Avatar
yellow01
What changes did you make? You say exhaust - meaning catback only or headers?
Honestly it just sounds like a dead battery to me...got someone that can jumpstart you?
Old May 14, 2005 | 02:00 AM
D stock 1's Avatar
D stock 1
Catback was the only thing that was added.
I just got the car back from the dealer earlier today do to
the steering wheel locking even though the bypass has been installed.
7 months ago.
Something in the fuse box is making a clickin noise.
Old May 14, 2005 | 10:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have a loose /bad battery cable connection or a dead/defective battery. Remove the battery and charge it. Have it checked out at an auto parts store to see if it is good. Clean the cable terminals and clean then with a wire brush and spray the terminals out with brake parts cleaner. Then spray them out with WD-40.
When you reconnect them, torque them to 11 FT/LBS.
Let us know how you make out.
Bill
Old May 14, 2005 | 08:19 PM
jimcork1's Avatar
jimcork1
My $$ is on bad battery. I was installing a power window motor once and it took about an hour. I tried the new motor and it would not run. Voltage was checked and low. Dah.. the dome light had been on for the hour and the marginal battery died. I jumped the car off, and suprise the new power window motor worked.
so,,, Batteries can die at any time,, it just adds confusion when you happen to be working on the car at the same time.
Old May 15, 2005 | 10:43 AM
99 vett babycar's Avatar
99 vett babycar
Old May 15, 2005 | 02:06 PM
vette2k1's Avatar
vette2k1
The symptoms that you describe sound like a dead battery.Try a jump start. If that works it is the battery.
To Need help!!!
