McLeod clutch install / removal - HELP!
Old May 15, 2005 | 11:26 PM
JCOB2's Avatar
JCOB2
Default McLeod clutch install / removal - HELP!
All of the clutch DIY guides show the clutch & PP sliding out by just removing the flywheel inspection cover. I have a McLeod twin-disk that I am trying to get out, and the problem is that it is MUCH taller (wider) and physically will not make it out of the bellhousing through the inspection cover hole. It appears that I have to remove the actual bellhousing cover.
This appears to be a PITA!
I see 6 bolts, 4 of which are incredibly inaccessible. They are waaaay up in the firewall, with absolutely no room or clearance to get any sort of wrench or ratchet up in there.
So my question is, to those who have remove a McLeod twin disk before, is there any way possible to sneak it out through the inspection cover opening? (i dont see how)...
Or, what is the procedure for removing the bellhousing cover. Do I need to lower the front cradle or something crazy like that?!?
Old May 15, 2005 | 11:40 PM
IFLUBYU's Avatar
IFLUBYU
Dunno if this pic helps, but here is where we were when the clutch components were replaced.
Old May 16, 2005 | 10:50 AM
JCOB2's Avatar
JCOB2
Ya, I wish it were that easy for me...
That big silver bellhousing, inbetween the camera and clutch in your picture... that needs to come out for me I think. My clutch does not fit up into that opening that your Exedy slipped up into. The McLeod is too wide to fit. Unless I am missing something, or there is some trick to it, which is what I am wondering from those who have done a McLeod twin disk before.
To McLeod clutch install / removal - HELP!
