header install
Old May 16, 2005 | 08:48 PM
fioremike's Avatar
fioremike
Default header install
Had headers installed car is backfiring alot any ideas?
Old May 16, 2005 | 09:06 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Did you get it retuned?
Ron
Old May 16, 2005 | 09:16 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Ron
Old May 16, 2005 | 09:43 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Sounds like your 02's are crossed.
Old May 16, 2005 | 09:58 PM
dragon84's Avatar
dragon84
Dude, I just did the same thing. You 02s are crossed. make sure you attach the original rear 02 sensores from the car to the front 02 holes in the headers. Also make sure that the right side 02 sensor plugs into the right side header hole and vise versa. I used black and white directions and went too fast. I was stumped for a week and then it hit me. Well that and guys on here calling me a dumba$$, but hey trial by error. Thats what makes hot rodding so fun. Good luck. Any more questions just ask me.
Old May 17, 2005 | 07:09 AM
purrvert's Avatar
purrvert
Cracked #7 plug when I installed my headers.
Old May 17, 2005 | 08:57 PM
fioremike's Avatar
fioremike
Thanks for reply its a04 zo6 w/4 oxygen sensors The headers also had 4 holes for oxygen sensor the mechanic said he put the sensors in same posistion as stock
Old May 17, 2005 | 10:14 PM
TLKSCHP's Avatar
TLKSCHP
If it's poping when your taking foot off the gas I would say you have some exhaust leaks at the header flanges. Thats what mine was doing, now it's fixed.
Old May 17, 2005 | 10:26 PM
dragon84's Avatar
dragon84
did u get 02 sims?
Old May 18, 2005 | 12:30 AM
dragonfly's Avatar
dragonfly
Hey, I had fioremike's headers in my garage....(long story) his had 4 bungs cats and all. So he could not have had an issue with swapping the O2 sensors front to back. I have the same style Melrose headers on my car. I get back firing only at low gear while engine braking..... and it is bad. If you leave the clutch it, or use leave it in a higher gear I doo not hear the back firing at all.
I have noticed that under hard accel (12.4@114.7), or any WOT experience the smoke is much worse and I am blaming this on running rich.
I am also very intrigued by Dragon's post. My set had no cats, am I supposed to use the rear o2 in the front bungs???????????? I did not get the fancy instructions like mike
I currently have the front o2 installed, and the rear o2 laying on my work bench (yes it throws a code)
Old May 18, 2005 | 07:15 AM
MY03Z's Avatar
MY03Z
I have the same problem with mine. I'm getting my tune today. I'll be picking the car up this weekend. I'll post after I get my car with dyno results good luck.
Old May 19, 2005 | 12:06 AM
dragonfly's Avatar
dragonfly
Anyone, the set you put back on the car without cats is the front pair? right?
Old May 19, 2005 | 06:56 AM
MY03Z's Avatar
MY03Z
use the rear 02's on the front with adapters
To header install
