headlight problem
Old May 17, 2005 | 11:19 AM
chevymits's Avatar
chevymits
1st Gear
Default headlight problem
My headlight doors make a loud growling sound for 15 seconds after they close. Can anyone tell me the fix?
Old May 17, 2005 | 11:27 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
order gear from rodneydickman.com
hmmmm...the link to my tech write up goes to someone elses thread and its all F'd up....WTF
Old May 17, 2005 | 11:35 AM
pewter99's Avatar
pewter99
PM me and I can tell ya what you need to do
Old May 17, 2005 | 11:40 AM
Andy H's Avatar
Andy H
I'm with pewter99. Just did both of mine this weekend. Only one gear was bad (chewed up) but didn't want to risk the other one going as well.
Rodney's product is excellent. the instructions are good. Couple of things on my 99 - there were only two 13mm bolts (not three) holding the headlight assemblies to the frame. The motor cover was held on with 6mm bolts. DO be carefull when pulling out the shaft assembly. there are a couple of white plastic spaces which can at first seem like a part of the plastic gear and there is a metal washer on the cover end.
I used the opportunity to upgrade the lighting to Sylvianna??? Silverstar bulbs and now I can finally see at night! If you were thinking of upgrading the lighting somewhat - this is the time to do it.
Whole project took a couple of hours with hand tools.
IMHO, well worth the time and money.
Andy.
To headlight problem
