Cooling fan problem?
Old May 18, 2005 | 10:53 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default Cooling fan problem?
2000 Vert - I am having - or seem to have- a problem with cooling. It seems unless I have the air cond on - the fan is not coming on early enough - or not at all - not sure at this point. If I have the air on - it seems to work fine - keeps failry cool - usually less than 220. If I don't have the air cond on - then the temp will rise quickly to 230+ - especially in stop and go traffic. any suggestions are apreciated.
(I suppose I will have to take it to the stealers and have them fix it?)
Old May 20, 2005 | 12:03 AM
ErnieD's Avatar
ErnieD
St. Jude Donor '16-'17,'19
Surprised our cooling experts haven't calmed your fears yet; your temps & system performance sound perfectly normal. Low fan is on at low speed with A/C on, but otherwise low fan comes on only when temp rises to about 225, and high fan at about 235. If your car performs that way and holds at about 192 to 196 at hiway speeds, it's doing what it was designed to do. Hope this helps.
Ernie
Old May 20, 2005 | 01:52 AM
leaftye's Avatar
leaftye
Ernie
Those are the stock settings.
Old May 25, 2005 | 02:08 PM
1stGlance's Avatar
1stGlance
Thanks guys - appreciate the inforamtion !
Old May 25, 2005 | 02:11 PM
2000BSME's Avatar
2000BSME
get a Predator and a 160 tstat.
Old May 25, 2005 | 02:18 PM
94legaleagle's Avatar
94legaleagle
I haven't driven my 2001 yet - it just went to the body shop yesterday to complete rebuilding process, but this thread has started a question in my mind:
My car's stock - should I replace the Tstat w/ a 160 degree Tstat as part of my rebuilding? What do I gain w/ the 160 degree Tstat over the stock one currently in place?
Bill.
Old May 25, 2005 | 03:17 PM
Fast one's Avatar
Fast one
Low fan means both fans are wired in series so they both operate at low rpms, high fan means both fans are wired in parallel so they both operate at high rpms. The computer controls three relays to change the wiring.
To Cooling fan problem?
