Need Help with code TCS - C1281 Current
Old May 18, 2005 | 05:34 PM
TheHammer's Avatar
TheHammer
Default Need Help with code TCS - C1281 Current
I keep getting this code. It is "Steering Sensor Uncorrelated Malfunction". What is the problem where is the sensor, and how can I fix it?
Old May 18, 2005 | 05:56 PM
0to60B4U's Avatar
0to60B4U
I had the same thing happen last night. I will be interested to hear about this too.
Old May 18, 2005 | 05:59 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Steering Column Sensor
________________________________________ ____________________
[TheHammer]I keep getting this code. It is "Steering Sensor Uncorrelated Malfunction". What is the problem where is the sensor, and how can I fix it?
This happened to my car a few years ago. It's located at the base of the steering column. I believe the steering column has to be removed in order to replace the sensor. I believe the sensor tells the computer what angle your wheels are turned which is also tied into the traction control feature. The "Vette Doctors" cured my car's ailment. I recently got this code again when I changed my shocks and didn't put the "A Frame" spacers back where they originally came from.
Old May 18, 2005 | 08:27 PM
TheHammer's Avatar
TheHammer
Anyone have pictures? I am not as familiar with the steering components of the car as other parts. I would like to know if I will be able to fix this myself, and a possible way to troubleshoot the actual problem to insure that it is just connection/ground issues.
Old May 19, 2005 | 02:42 AM
TheHammer's Avatar
TheHammer
ttt
To Need Help with code TCS - C1281 Current
