My right turn signal is not working...the lights are on,but when i use the right signal the green arrow on the cockpit goes on and off very fast...but out side nothing happen...could be a fuse?
Pleas Help!!
thanks in advance...
Compare both sides. The first time I had a front corner lamp go out, I didn't really know what was out because I didn't know there were two bulbs in the corner lamp. The 2nd bulb made me think it was still good. If you closely compare both sides, I think you'll spot the difference. If you have thin arms, you can reach the bulbs thru the hole for the brake duct. Push the brake duct down and towards the center of the car, and you'll be able to reach both corner bulbs.
FWIW, I believe if the fuse it out, or removed, the blinker wouldn't blink fast, and the car won't throw error codes. I might have to try this out to confirm it, but lots of people pull the daytime running light fuse.
