I purchased new tires yesterday and decided to go with a different brand that I can run at a higher psi. As you all know the sensors will freak out on me if I actually go with the 50psi rating.
So is there a way to change the high and low numbers for the computer some how?
Its early in the moring here so if thats a stupid question take it easy on me...lol.
Have a great day!!
In answer to your question: NO, you can not reprogram the system to alert you at different pressures. The "high and low" warnings are pre-set. To follow with other posters: WHY? The pressure you should run is for the car, not the maximum on the side of the tire. Can't imagine running 51 PSI would be "productive".
