Help with DIC code!!!
Old May 22, 2005 | 12:25 PM
Aaron's-coupe's Avatar
Aaron's-coupe
Default Help with DIC code!!!
Can someone hlep me with these codes. I checked the codes today and fave found some unsual codes that I am not sure what they are.
the codes are C2105 HC, C2110HC, C2115HC
The only thing I have regarding codes tells me they are "TPM Sensor Malfunction -TPM"
That is this? Thanks for all your help
Aaron
Old May 22, 2005 | 01:12 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Aaron
Aaron,
The codes are in reference to your tire pressure sensors.
05 is RF, 10 is RR and 15 is LR.
If those are the original sensors (7yrs old) they could be starting to die on you.
But first you should try to reprogram them. Sometimes that's all it takes.
Click on this link for the procedure:
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old May 22, 2005 | 09:26 PM
Aaron's-coupe
Thanks. I know the sensors are bad, I just was concerned with the codes...
Thanks for your help.
To Help with DIC code!!!
