iPOD dock and install for C5
Old May 22, 2005 | 08:34 PM
Webz's Avatar
Webz
Default iPOD dock and install for C5
I am looking for an easy to install iPOD dock that will fit into my C5. Needs to include the recharger and FM radio broadcast features. I am open to other options which have been successful as well. Thanks.
Old May 22, 2005 | 08:47 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Do a search on the forum. There have been many posts about what you are looking for. Some people have hardwired their connection.
Old May 22, 2005 | 09:36 PM
acowboy's Avatar
acowboy
i have the Z hardwired, but, i switch ipod between vehicles using New Tech RoadTriphttp://www.ipodlounge.com/index.php/...nsmitter-ipod/ ....is a charger and modulator combo....this thing works! had been using Itrip, but, this is way better..very clean sound...also, mount ipod in ProClip dashmount....http://www.proclipusa.com/home/home.aspx
Old May 22, 2005 | 11:14 PM
88sk's Avatar
88sk
walmart has a similar one that goes into the h-phone jack made by Scosche & is $17 & works excellent,you can plug it into the console cig. aux. outlet for a stealth look.
Old May 23, 2005 | 01:52 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Care to post a link?
Old May 23, 2005 | 02:54 PM
houston-z06's Avatar
houston-z06
Default Check this link out...
I am going to do this, will let you know how it works.
Anyone else have this set-up?
http://www.mp3yourcar.com/search.asp
Old May 24, 2005 | 11:11 AM
screw991le's Avatar
screw991le
Keep us posted, if it works I'll get 2
http://www.mp3yourcar.com/productdet...p?productID=86
Old May 24, 2005 | 04:59 PM
LarryW's Avatar
LarryW
I can't comment on the FM modular type of adapter since I'm not using one, however...
I am using the direct connect type mentioned by a couple of the previous posters: mp3yourcar and I'm really happy with it. The installation was very easy (virtually plug and play; you can purchase all necessary cables through these guys). It's an expensive solution but it will allow you to control your iPod through the factory head unit including: power on/off the iPod, FF/RWD to the next track, control the volume, and most importantly to me: automatically recharge your iPod's battery when physically connected.
To iPOD dock and install for C5
