Help.. Weird Problem!!!
Old May 27, 2005 | 09:01 AM
VT's Avatar
VT
Default Help.. Weird Problem!!!
OK, I need help fast, I will try and explain it best I can, but my warranty runs up in 10 days and I don't know if I need to take it to the dealer.. Here it goes.
At first I thought I had a clutch going bad, in 4th gear around 1800 RPM's under FULL throttle there is on and off hesitation and what felt like the clutch slipping. Once it is above 3.5-4K I can't really feel it. It only seems to be in 3rd and 4th gear. 2nd still pulls strong so it can't be the clutch. I pull the codes thinking maybe I have a miss or pre-ignition but nothing shows up. This is a Y2k with 25k miles a blackwing, corsa, and nylon maf ends. Could I need new plugs wires? I am lost... Almost wishing it was the clutch, at least that would be easy to troubleshoot. Thanks in Advance..
Dave
