Dynatechs in from top???
Old May 27, 2005 | 04:15 PM
molson's Avatar
molson
Default Dynatechs in from top???
Like the title says...is it possible?
I thought I read a post where someone accomplished this.
I removed the steering shaft,does the valve cover have to come off?
Old May 27, 2005 | 04:24 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If I remember correctly (did this a few weeks ago) the driver side header goes in from underneath, and the passenger side goes in from the top..on the passenger side, you will also have to remove the starter.. oh and careful not to break your oil level sensor line while doing this ...that took a while to micor-solder back I did not remove any valve covers but did remove coil packs, plugs/wires etc..
Old May 27, 2005 | 04:27 PM
molson's Avatar
molson
Thanks for the response..
The pass. side was easy..drivers side a prob.
I don't think I can get my car high enough in my garage to go in from the bottom.
Old May 27, 2005 | 04:36 PM
SinCity-Z's Avatar
SinCity-Z
They can both go in from the top! You do not have to remove the starter.
Disconect Batt
Driver side Remove the Alt, Coil pack, Fuel line @ fuel rail, steering shaft bolt @ rack, and Valve cover.
Pass Side Remove Coil pack, dip stick, valve cover.
I may have missed something but you get the idea. BTW I have installed several short tubes the Dynatechs and LG long tubes from the top without any problems. I did a set of LG's last week and had to remove th oil filter to get the driver side on.
Good Luck
Monty
Old May 27, 2005 | 05:12 PM
molson's Avatar
molson
Thanks..
I needed to know it wasn't impossible.
Old May 27, 2005 | 08:47 PM
MUKAK's Avatar
MUKAK
Disconect Batt
Good Luck
Monty
Are you sure about not having to remove the STARTER????????
Where did you hear that?????
I wasted 1 hour trying to not to remove the starter, to save time but at the end had to get the starter out
For the driver side, if you remove stuff you just named it will take another 2 hours of labor, than sticking them from under
IF YOU DONT KNOW DONT SPREAD RUMORS, do your homework first
Yeah you did several SHORT TUBE HEADERS, but i bet never long tubes without any problems
Old May 27, 2005 | 09:47 PM
SinCity-Z's Avatar
SinCity-Z
MukaksC5,
Please re-read my post. I have done both long tubes and short tubes. I had Dynatech's (sold) on my car a couple of months ago that I put on last November. And last week I installed a set of LG long tubes. The instructions said to put in from the bottom. They easily went in from the top on the passenger side. I did have to remove the oil filter on the driver’s side. BTW the dynatech's were easier both going in and coming out compared to the LG's.
Sorry you had so many problems as it only took me 2-3 minutes Pass, 5-10 minutes Drivers to set them in while not scratching the nice Jet Hot finish that is on them.
Monty
P.S. I have installed 15-20 Sets of headers (L&S) in C5's. BTW Molson posted that he had no problem on the passenger side which is the side the starter is located on!
Old May 27, 2005 | 11:15 PM
molson's Avatar
molson
Thanks for all replys...
I got the driver side in after removing the valve cover and fuel rail...I don't have a fuel disconnect tool.
It went in easy after that..
It set me back about an hour but it was worth it...and by the way I didn't have to remove the starter.... just the bolts.
Old May 28, 2005 | 01:05 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Glad to see you got them in. I should have been more clear in my post...you don't have to Remove the start completley so to speak..but take the bolts out so you can shift it a little if need be to make it easier.
Old May 28, 2005 | 10:41 PM
2KREDVert's Avatar
2KREDVert
[QUOTE=SinCity-Z]MukaksC5,
Monty
Why would you coat SS headers? Isn't that a little overkill?
Phil
Old May 29, 2005 | 01:35 PM
leaftye's Avatar
leaftye
[QUOTE=2KREDVert]
MukaksC5,
Monty
Phil
Overkill? What's that??
To Dynatechs in from top???
