Column Lock finally got me!
Old May 27, 2005 | 08:57 PM
Neeko's Avatar
Neeko
Default Column Lock finally got me!
After 4 1/2 years i finally got stuck by the column lock. Luckily i wasnt in the middle of nowhere. Had no choice but to tow it to the dealer. I've read about recalls on this site but never got one from GM. I also hear good and bad things about the bypass kit. Lets see what this guy says after the holiday. He better be gentle! I know this is an old story but it finally happened to me so i have to share. thanks guys!
Old May 27, 2005 | 09:15 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Wow! I feel your pain. I bit the bullitt and did the CLB(on advice of the forum) It is worth the peace of mind.
Old May 27, 2005 | 10:27 PM
Mike94ZLT1's Avatar
Mike94ZLT1
What is column lock and how do I keep this from happening to me? (corvette newbie here)
Old May 27, 2005 | 10:38 PM
Dave68's Avatar
Dave68
My 01 lasted through about 1500 actuations before the column lock actuator finally bit the dust. I installed a column lock bypass within a week of this occuring and will not have to worry about it any more.
To the newbie, if you hear a bvvvvvt noise every time you turn the ignition off or on, you have the factory column lock and it WILL fail some day, potentially leaving you stranded. If you do still have the factory column lock, buy a bypass kit for $50 and install it ASAP. Installation takes about 30 minutes and detailed instructions can be found at http://www.97vette.com/
Old May 28, 2005 | 01:54 AM
Shylor's Avatar
Shylor
Did you try the steering wheel freeing technique others have suggested and claim works every time?
Old May 28, 2005 | 09:00 AM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I installed the Column Lock Bypass yesterday on my 04, purchased from Thunder Racing a couple months ago. Peace of Mind now
Old May 28, 2005 | 10:10 PM
tnsyty's Avatar
tnsyty
My cloumn lock has been stuck open for 3 months. I always reset the messege. So far NO problems. I wanted to do a CLB but figure I will stick with this locked open problem I have.
Old May 28, 2005 | 11:43 PM
lost's Avatar
lost
Mine locked up six times in the 2 1/2 years I have owned it.Never took more than ten minutes to unlock it, but after my third recall notice took it in and had it done.A-4s are a snap , as of three weeks ago the six speed fix was not working, according to the dealer that did mine.
Old May 28, 2005 | 11:44 PM
VIPER52USA's Avatar
VIPER52USA
My car makes a rattle/clanking sound when I shut it off. I was wondering what it was. So the clank/rattle sound is the colum lock?
Old May 29, 2005 | 03:11 AM
Dave68's Avatar
Dave68
If the actuator fails in the lock position, no amount of jiggling the wheel or cycling power will free it. I had to have mine flat-bedded to the dealer.
No, the column lock sound is a high-pitch buzz-kind of sound that occurs after you turn the key to the "on" position and after turning the key to the "off" position.
Old May 29, 2005 | 09:24 AM
VIPER52USA's Avatar
VIPER52USA
Then what is the sound that my car is making? The dealer said it was completely normal, but it doesn't seem as if it should be making that kind of sound.
Old May 29, 2005 | 09:59 AM
Mr.Z-06's Avatar
Mr.Z-06
Default Shut it down with clutch engaged...
My guess is you're not turning it off with the clutch pushed in. Try it, I think you'll find it doesn't do it.
-Mr.Z-06
Old May 29, 2005 | 10:31 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Steering Lock
Im going Thursday to the dealer, Im going to make sure they dont mess around with the computer thought............Im staying there if I have to
Old May 30, 2005 | 01:46 AM
Shylor's Avatar
Shylor
That is not what some people claim.
Old Jun 3, 2005 | 07:28 PM
JJ in FL's Avatar
JJ in FL
Not true. You can unlock it manually. All you have to do is force the wheel to the right as you turn the key to the "on" position. It frees itself everytime.
Old Jun 3, 2005 | 10:42 PM
ECV-Tony's Avatar
ECV-Tony
How old is your battery as this may also contribute to the prob.
Old Jun 3, 2005 | 10:44 PM
ECV-Tony's Avatar
ECV-Tony
Hey HEB, how difficult was it? I've got to do the same thing here in the near future.
To Column Lock finally got me!
Old Jun 4, 2005 | 08:22 AM
Rattler71's Avatar
Rattler71
I put 2 different bypass's in my 04 and both times the water temp guage would peg out(not hot water, guage issue). May try again in the future, after all my water leak issues are fixed by the dealer.
Scott
Old Jun 4, 2005 | 09:55 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes, turn the wheel to the right when turning the key, THIS SHOULD BE THE FIRST THING IN THE STICKY AT THE TOP OF THIS SECTION!! it save me last week
Old Jun 5, 2005 | 09:19 PM
z06matt's Avatar
z06matt
Thank you guys! Yall are awesome... My column locked a couple hours ago and I thought I would have to have it towed to the dealership but I did a search and found this thread! and that worked
