Park Brake help needed...
Old May 31, 2005 | 07:31 PM
FRCTony's Avatar
FRCTony
Well, it's done. I have included the picture below to help others who might make foolish posts asking for help
It appears there were two problems.
1. Grease used by the factory turns liquid and runs off the actuator bolt (6), causing it to become fused to the "star wheel" (7). On the right rear, the grease had literally run out of the bottom of the housing (5). I needed a torch to heat (7) so that I could free the bolt on the LR. There was no evidence that the park brake had been abused, and the car still has the original brake pads and rotors at 48K.
2. The actuator bolt (6) was flush against the "star wheel" (7) on both acuators. I believe it left the factory that way. I surmise that if the acuator bolt had been adjusted properly, the lack of grease would not have mattered.
Thanks to all for your help!
Old Jun 6, 2005 | 01:14 PM
DSchaefe's Avatar
DSchaefe
This post was a big help to me and fixing my parking brake. My star wheels were also flush with the actuator and seized together. A little heat and a couple light hits with a hammer and the came loose. All adjusted now and working great.
Old Jul 25, 2005 | 09:21 AM
jwg2's Avatar
jwg2
This is a good tip. I'd been messing around with all the proposed solutions, but eventually discovered the actuator and star wheel was siezed. some heat and percussive persuasion freed it up, and now the e-brake works
Old Jul 25, 2005 | 02:05 PM
javamon's Avatar
javamon
Thanks for the update. I've got the A4 and there's no hills here so to hell with the emergency brake. What an idiotic design! I think the engineer who designed this got promoted to designing cup holders.
