Installed Crane 1.8's
Old May 30, 2005 | 01:20 AM
hightest's Avatar
hightest
Default Installed Crane 1.8's
I decided to try the crane 1.8 roller rockers, and see just what kind of a difference they would make. I also installe the comp 918 springs and titanium retainers to compensate for the slightly higher lift.
Dyno before the rockers - with Blackwing, shorty headers, ported TB, LS6 intake manifold, SLP 85mm MAF, high flow cats, B&B PRT's, 3:42 gears (some say that the lower gears reduce your hp reading on the dyno), and stock wheels & runflats. 334.3 hp @ 5850 rpm's & 334.7 lb.ft. of torque @ 4700 rpm's. The a/f ratio was at 13.5 (only have 91 octane here).
Dyno after the 1.8 crane rocker install - same mods, but with 20 inch iforged wheels (possibly a lower reading than with the stock wheels and tires). 340.2 hp @ 6000 rpm's & 321.9 lb.ft. of torque @ 4700 rpm's. a/f also at 13.5.
Only a 5.7 hp gain, but a reduction of 12.8 lb.ft. of torque. doesn't seem worth the money in my opinion.
Anyone else out there get similar results? Maybe the bigger wheels and tires would account for the big torque reductions.
Old May 30, 2005 | 06:12 AM
Tino's Avatar
Tino
Could it be that your 20 inch rims reduced your gear ratio and hence your torque multiplier? Wonder what it would have been with the same wheel package?
Tino
Old May 30, 2005 | 09:16 AM
XTrooper's Avatar
XTrooper
I switched from a set of SLP 1.85 rockers to the Crane 1.80 roller rockers, lost ~.010" of valve lift in the process due to the lower ratio, and still gained 10 rwhp and 8 rwtq with the Cranes over the SLPs.
Your conclusion isn't fair because I think the wheel change made any real comparison impossible.
Old May 30, 2005 | 09:22 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We typically see 16/11 flywheel gain on nearly every engine we've installed them on using a Superflow SF-900 engine pump and the power curve is MUCH broader, especially in the low-to-mid range area.
Old May 30, 2005 | 11:56 AM
Just Enough's Avatar
Just Enough
Comp 918s are a beehive type spring, I have heard that some beehive springs have natural frequencies which are excited in the 4500-6000 rpm range in LS1/LS6s and the noise from their vibration triggers the knock retard. You can't hear this noise over the roar of the engine at these rpms but a scan tool should reveal if you are experiencing any knock retard which would be stealing your torque.
Old May 30, 2005 | 12:27 PM
T_Vert's Avatar
T_Vert
i put on 918s and 1.85 Roller rockers and gained nothing at the track. ET/MPH withing .05 between the two days. DA was very similar and AFR was identical. This was on a stock C5. Wasnt worth it. Ditto on the LS6 intake.
Dave
Old May 30, 2005 | 12:56 PM
Chrispy's Avatar
Chrispy
Those rims are REALLY skewing the results. Borrow a set of stockers and redyno. (rotational weight from the bigger wheels will eat a lot of power)
Old May 30, 2005 | 01:09 PM
Tino's Avatar
Tino
I tend to agree with Chrispy .... don't right it off just yet.
Tino
Old May 30, 2005 | 02:19 PM
XTrooper's Avatar
XTrooper
Dave
One word: tuning. You can't just slap this stuff on and go. If you do, then you're right, it's not worth it.
Old May 30, 2005 | 02:29 PM
T_Vert's Avatar
T_Vert
Read, exact AFR. I did tune it. At WOT the only thing that matters is AFR really. Same timing tables
Dave
Old May 30, 2005 | 02:32 PM
Just Enough
DynoTech Engineering, What springs do you typically use for the Crane 1.8 install?
Old May 30, 2005 | 02:41 PM
DTE Powertrain
Collections Hold
We use the Crane Cams dual valve springs w/ titanium valve spring retainers and to the person that stated that there is no other spark delivery tuning necessary with these types of mechanical modifications other than fueling...... Well, by not optimizing ALL areas of the calibration, especially by not performing any adjustment in spark delivery, you are certainly leaving power on the table by not doing so as evidenced by no E.T. gain in your combination.
Spark delivery DEFINATELY matters....FYI
Old May 30, 2005 | 06:02 PM
XTrooper's Avatar
XTrooper
Dave
That's an incorrection assumption and your results confirm it. The LS6 intake manifold alone should have given you some gains. The manifold and the 1.80 rockers certainly should have.
Old May 30, 2005 | 06:05 PM
XTrooper's Avatar
XTrooper
I too am using the Crane dual valve springs. FWIW, when I first installed the Crane 1.80 Quick-Lift rockers, I was using them with a set of PRC dual valve springs and got a wicked power dip at about 5900 rpm. Mark Campbell, VP of R&D for Crane Cams, told me it was very likely being caused by valve spring harmonics/valve float. I swapped out the PRCs for the Cranes and the dip disappeared.
Old May 30, 2005 | 06:15 PM
vettenuts's Avatar
vettenuts
What timing chain are you guys running with the Crane springs?
Old May 30, 2005 | 06:52 PM
DTE Powertrain
Collections Hold
Crane adjustable 3-piece timing chain sets is what we use here. (they are manufactured by Rollmaster to Crane Cams-specific specs/design)
Old May 30, 2005 | 09:36 PM
T_Vert's Avatar
T_Vert
i did play w/ spark advance but got nowhere. No ET or MPH gains as far as adding/removing timing or adding removing fuel with the mods. If AFR is the same (13.0:1) and spark timing is the same why would changing them affect anything? I did mess w/ timing but it didnt do a thing to ET or mPH. What else would you have to change when adding RRs or the intake? Mind you this was on a pretty stock car so this could be why there were no gains, but I can guarantee I did everything to try to get power from them. I didnt want to have to take them back off. I can give more details as far as tuning changes, time slips, Density altitude and logs of runs in HPT if anyone is interested.
On a stock to mildly modded car, the springs, rockers and ls6 intake will give you almost nothing.
Dave
To Installed Crane 1.8's
Old May 30, 2005 | 10:41 PM
hightest's Avatar
hightest
When I get back into town next week I will put the stock wheels and tires back on and dyno the car again. I'm curious myself as to wether there is any real significant change from just wheels and tires.
I should also make everyone aware that all of the necessary tuning was done to achieve max hp and torque. That last dyno run was #6, the first five runs were for tuning.
Old May 31, 2005 | 08:30 AM
XTrooper's Avatar
XTrooper
I'm using a Rollmaster double.
Old May 31, 2005 | 07:00 PM
vettenuts's Avatar
vettenuts
While I am interested in the rockers, I am nervous about going to stout with the springs with the stock timing chain. To change it, I might as well do the cam at that point.
