HELP keep getting this Code
Old Jun 1, 2005 | 02:43 PM
vette-time's Avatar
vette-time
Default HELP keep getting this Code
I keep getting this Code PO650 could someone tell me what this mean.
THANKS
Old Jun 1, 2005 | 04:15 PM
Dave03's Avatar
Dave03
Default C5 Computer Codes
Go to http://www.stengel.net/diccodes.htm . Codes are listed there.
Old Jun 1, 2005 | 06:01 PM
Richin Chicago's Avatar
Richin Chicago
THANKS
Something is wrong with your check engine light.
CIRCUIT DESCRIPTION
A voltage is supplied directly to the Malfunction Indicator Lamp (MIL) . The PCM controls the lamp by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line which is monitored by the PCM. When the PCM is commanding a component ON, the voltage of the control circuit should be low (near 0 volts ). When the PCM is commanding the control circuit to a component OFF, the voltage potential of the circuit should be high (near battery voltage). If the fault detection circuit senses a voltage other than what is expected, the fault line status will change causing the DTC to set.
Old Jun 1, 2005 | 07:51 PM
vette-time's Avatar
vette-time
To HELP keep getting this Code
