Should I replace the clutch?
Old Jun 1, 2005 | 07:57 PM
Vettman 1's Avatar
Vettman 1
Default Should I replace the clutch?
My mn6 is at the dealer with the rear end removed. Something internal is causing the L/H seal to leak. I'm not sure yet whether they're going to repair, or replace the differential. My question is with the rear end out and on the ground how much more is involved in replacing the clutch, pressure plate etc. The rear end is covered by warranty, the clutch would be on me. Car has 41K easy miles, so it may be completely unnecessary (but prudent as I plane to keep the car for a long time).
Old Jun 1, 2005 | 10:12 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You're half way there but if there isn't a problem with it and you don't plan on big mods later don't worry about it.
Old Jun 1, 2005 | 10:21 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I would replace it.
Old Jun 1, 2005 | 10:32 PM
Vettman 1's Avatar
Vettman 1
Thanks, I think I'll calll the dealer and at least find out the cost. I think most of it would be labor if it was to be replaced from scratch.
Old Jun 1, 2005 | 11:15 PM
Ranger's Avatar
Ranger
If the clutch doesn't have many hard launches on it and is not exhibiting any issues, I'd leave it alone.
If you are incline to swap it out, you might want to read though a couple threads that result from search on "clutch" + "vibration".
Doing that should help you understand how crucial the install procedures are (the tech) to the ontcome.
Just a thought.
Ranger
Old Jun 2, 2005 | 02:49 AM
blackbelt's Avatar
blackbelt
If you do plan mods i would do it for sure. It will save you time and money later cause you will have to do it. Heck if you do do it soon I will even buy your stock clutch. let me know
Old Jun 2, 2005 | 07:06 PM
yazu's Avatar
yazu
had a dealer put one in my car with only 36k on it. coast me 1500.00
i can say atleast they did a good job.
Old Jun 2, 2005 | 09:23 PM
silverz06vette's Avatar
silverz06vette
If you can buy the parts from Gene @ Fred Beans and they will install them I would do it. At least have them install a new slave, its $100 from Gene. Also have them install a clutch extender bleeder.
Old Jun 2, 2005 | 10:16 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
new slave cylinder is probably more worth it than new clutch...My clutch was fine when I took it out to replace the slave but I replaced the clutch while I had it apart anyways
Old Jun 2, 2005 | 10:27 PM
Tsab's Avatar
Tsab
If you plan on Keeping the car for a while then do the clutch. I would install the Z06 clutch if you don't plan on Beating (racing) on it every weekend. Make sure they check the balance on the new clutch assembly before installing it.
To Should I replace the clutch?
