2001 Coupe with original battery
Old Jun 2, 2005 | 02:27 PM
davidwp97's Avatar
davidwp97
Default 2001 Coupe with original battery
My 40,000 mile, 2001 MN6 Coupe has the original battery. I drive the car year round (no storage). How soon should I consider replacing the battery? We take long trips and I don't want to get stranded in the boonies.
Thanks,
Old Jun 2, 2005 | 02:36 PM
Ginzo's Avatar
Ginzo
Most car batterys on average last 5 years. If you can't take the risk then now would be a good time or just get AAA.
Old Jun 2, 2005 | 02:48 PM
cenzo's Avatar
cenzo
Thanks,
Now would be a good time.
Old Jun 2, 2005 | 03:44 PM
Dave68's Avatar
Dave68
My 01 has the original battery in it also. Since 01 was the first year in which this AGM battery was used, no one knows what its potential is. In Miatas, AGM batteries have been known to last 7 years or more under the right conditions. I'd say that if you drive your C5 regularly and for long enough distances, you may be able to get another 2 years or more out of it. My AGM is still very strong at 4 years old.
Old Jun 2, 2005 | 07:25 PM
Paras's Avatar
Paras
What's AGM? My 2001 Coupe seems to be running ok with the same battery too...
Old Jun 2, 2005 | 07:29 PM
2001 Red Coupe Bandit's Avatar
I have a 2001 Coupe 4 Years 3 Months old with original Battery, 16,500 miles on car.
Ours has a tray to stop battery leakage,,,,right?
Old Jun 2, 2005 | 08:13 PM
INTHERED's Avatar
INTHERED
My 40,000 mile, 2001 MN6 Coupe has the original battery. I drive the car year round (no storage). How soon should I consider replacing the battery? We take long trips and I don't want to get stranded in the boonies.Thanks,
My 2000 still has the original battery and it is going strong. Most batteries do not fail over night so if it still turns over when cranking
as it does when it was new and the battery voltage is Ok when the
engine is off keep it. I have had great luck with the OEM AC-DELCO batteries and when mine gets weak I plan on replacing it with an AC.
INTHERED
Old Jun 2, 2005 | 09:13 PM
Dave68's Avatar
Dave68
The AC Delco AGM battery is a glass mat battery that is leak and vibration-proof. A few manufacturers make batteries of a similar construction, including Optima. Batteries that were OEM in 2000 and earlier C5s are lead-acid.
Old Jun 2, 2005 | 09:26 PM
FRCTony's Avatar
FRCTony
A good AGM will last a long time. The original in my Miata lasted 12 years.
To 2001 Coupe with original battery
