Problems lowering... HELP!
Old Jun 10, 2005 | 11:30 PM
corvette dave's Avatar
corvette dave
Chem,
It really does sound like you have tried everything.
However, I have had the same problem and was able to get vice grips on the metal part of the bushing and turn it.
Either you need a thinner pair or a longer pair to get in there. See if a friend has something that will work.
Or you might have to drop the lower control arm (not difficult) to get to the bushing.
Dave
Old Jun 11, 2005 | 12:10 AM
ronniej's Avatar
ronniej
St. Jude Donor '06
Try this approach:
https://www.corvetteforum.com/techti...D=90&TopicID=1
You drop the lower a arm and get to the bushing/bolt from underneath. I had the same problem as you the first time I lowered mine so your not alone. After fighting the first side, I went inside and read a little more and noticed how you had to put the jack under the spring to relieve tension and them I could actually turn it by hand. Hope this helps.
