Was just on the Z06Vette.com forum and have found several guys have recently broken valve springs. Just wondering if anyone has had this problem with the LS1 springs.
Broken valve springs are not uncommon on LS1s with aggressive after market cams. However with proper valve spring selection & maintainance broken valve springs can be avoided for the most part.
The reason for breakage is often not the spring quality. It's usually because they were installed with too much seat pressure. Combine that with an agressive cam profile and it's going to break the springs, even good dual ones.
The solution is to measure the installed height of the spring before you put them on (measure from ID locator to bottom of retainer) - that is what your spring will have for height when you put it on. Check that against what the spring manufacturer said the pressure is @ a given Installed Height.
If you think you will be closer to 150 Lbs of seat pressure than 120, you will be more likley to break again. (on most all dual springs and singles rated for the job). You really need a spring tester to do the job right. Just take one spring, take your measured installed height and goto any machine shop. They will test your spring at that height and tell you the seat pressure. Really, it's the right way to do it. I'm pretty picky but then again, we don't have broken springs.
Exactly, these are stock from the factory setups that are failing. Making me wonder if you might need preventative maintenance on the stockers at some prescribed mileage or if the failures are particular to one part number.
Checked the height on my stock springs that were removed when I did a cam swap and one spring out of the 16 was about 60 thousandths shorter than the rest. This was on springs that had 25000 miles of easy driving on them. Looks like it might have been a problem waiting to happen.
Also I wrote an article about flow numbers and how you should look at them when buying heads. Not too bad if you like to know the real details of things.
It's always good to have a Supporting Vendor jump in on tech stuff........
Another reason for breakage.................hitting the RL to many times makes for bad spring harmonics.
My only LS1 experience with breakage..........plan to keep it that way too but not for the lack of trying
