Help a C4 guy with C5 brakes
Old Jun 9, 2005 | 10:39 PM
FD2BLK's Avatar
FD2BLK
Default Help a C4 guy with C5 brakes
I am in the middle of a C5 brake upgrade and am missing some bolts. The bolts are the ones that connect the caliper to the pins. They are #2 in the bellow image. Can anyone tell me if these are just normal 8 grade bolts? A P/N would be a big help as well so I can try to get them local. One last question and it may sound stupid but the C4s don’t use them. That is what pad does the shim go on (Plastic stick on pad), the inner or outer brake pad. Any help would be great.
Thanks in advance FD2BLK
Old Jun 10, 2005 | 11:39 PM
VetteNoob's Avatar
VetteNoob
Here's all the part number info you will need.
http://www.superchevyperformance.com...s/c5brakes.asp
Old Jun 11, 2005 | 01:26 AM
Bill Dearborn's Avatar
Bill Dearborn
The bolts come as part of the standard C5 brake pad package from the dealer. After market pads do not provide them. You could probably get a caliper hardware rebuild kit with the pins and bolts included. The stock pads do not include any shims. Some aftermarket pads do.
Bill
Old Jun 11, 2005 | 01:31 AM
FD2BLK's Avatar
FD2BLK
Thanks guys i got it. They where just grade 8 bolts I was able to get local. They are the same ones used in early C4 applications. I already had all the pins ect.. From Chris May but bought the calipers used so the bolts wernt withthem. As for the shims, I bought GM pads from Superior chevy and Chris included a set of shims.
Again thanks for all the help heres a shot of the final product
Old Jun 11, 2005 | 01:37 AM
vett_girl's Avatar
vett_girl
Great looking vett
To Help a C4 guy with C5 brakes
